Go to Post I survived the Great CD Spamming of 2006. - Michelle Celio [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 19-01-2016, 16:03
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Can't seem to retrieve SmartDashboard data for PyNetworkTables?
Hi,
Today's problem of the day is the SmartDashboard. I am using this [summarized] code on the robot:
def robotInit(self):
     self.sensor = wpilib.AnalogInput(3)
     wpilib.SmartDashboard.putNumber("Clicky1", self.sensor.getValue())
def teleopPeriodic(self):
and this code on our driver station computer:
from networktables import NetworkTable
NetworkTable.setIPAddress("roborio-4480-frc.local")
NetworkTable.setClientMode()
NetworkTable.initialize()
sd - NetworkTable.getTable("SmartDashboard")
while True:
    try:
        print('distance:', sd.getNumber('Clicky1'))
    except KeyError:
        print('distance: N/A')
So I get a KeyError for when it tries to pull "Clicky1". Am I supposed to put more code on the robot to define the Clicky1 name? Or is there a way to make sure I am connected for sure to the robot? Sorry for all the questions.
Unread 19-01-2016, 17:39
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Can't seem to retrieve SmartDashboard data for PyNetworkTables?
That looks correct. There should be a log message that prints out when you actually connect to the robot. You need to enable logging to see it:
# To see messages from networktables, you must setup logging
import logging
logging.basicConfig(level=logging.DEBUG)
You probably want to add a sleep in that while loop.
I assume you've already looked through the samples?
Unread 19-01-2016, 19:43
team-4480's Avatar
Debug? What's that?
FRC #4480
import logging
So is that logging in the robot code or the driver station code? Thanks!
Unread 19-01-2016, 23:21
virtuald's Avatar
RobotPy Guy
The DS code. The robot already has logging enabled by default.
Unread 20-01-2016, 14:45
team-4480's Avatar
Debug? What's that?
FRC #4480
Is there a way to print out all the available keys? I still get the KeyError right away. Maybe it is not waiting to connect?
Unread 20-01-2016, 16:56
virtuald's Avatar
RobotPy Guy
Check out the global listener sample.
https://github.com/robotpy/pynetwork...al_listener.py
Unread 25-01-2016, 19:24
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
It's also broken for me.
it gives an error about incompatible version or whatever, so I think it rejects Network Tables 3.0.
Is there a way to get this to work with NT 3.0, or should I give up on PyNetworkTables?
Head Programmer / Driver
Unread 25-01-2016, 22:17
virtuald's Avatar
RobotPy Guy
If you're using LabVIEW then it will not work until we upgrade the implementation to NetworkTables 3.0 (tracked at this github issue). However, it should work correctly with Java/C++ NetworkTables client/servers, despite the warning about incompatible revisions.
The global listener sample is great for figuring out if the other side has placed anything in NetworkTables.
Unread 25-01-2016, 22:31
cjl2625's Avatar
apel py
AKA: Cory Lynch
Yes, I'm using LabVIEW. Is the upgrade anticipated to be before the end of the build season?
Unread 26-01-2016, 10:17
virtuald's Avatar
RobotPy Guy
Peter has been working on a full migration to NT 3.0, but it's a lot of effort and not done yet. I talked to Peter last night and he said he was going to look at putting together something quick this week that would allow us to be compatible with LabVIEW, as the question has come up a few times.
Unread 08-02-2016, 22:22
cjl2625's Avatar
apel py
AKA: Cory Lynch
It's been a couple weeks; any update on this?
Unread 09-02-2016, 10:24
virtuald's Avatar
RobotPy Guy
Peter said he's been busy, but has been working on it. He promised to post whatever he's got by Wednesday.
Unread 10-02-2016, 09:19
virtuald's Avatar
RobotPy Guy
Peter pushed a branch, can you try it out and let us know if it works for you? https://github.com/robotpy/pynetwork.../nt3-barebones
He hasn't tried it with LabVIEW, but says it works with the OutlineViewer + NT3.
Unread 11-02-2016, 21:03
cjl2625's Avatar
apel py
AKA: Cory Lynch
I gave it a shot, and it seems to work nicely.
Was able to upload values and they appeared on the LabVIEW dashboard.
Thanks.
Unread 14-02-2016, 19:36
virtuald's Avatar
RobotPy Guy
Thanks.
Cool. I've pushed an alpha release of this (2016.0.0alpha1) to pypi in case someone else needs it -- you'll need to specify the --pre argument to pip in order to install it.
