Go to Post No disclaimer on earth lets you disassociate yourself with your team or what you represent because you want to say something not particularly nice, but lets you be associated again when you want to say something to encourage others, etc. - Amanda Morrison [more]
Unread 26-01-2016, 11:01
snags snags is offline
FRC #5431 (Titian robotics)
Rookie Year: 2015
snags is an unknown quantity at this point
Re: Is this shooter design sound?
I would be careful using shaft collars to hold the assembly on the hex shaft. Our team has found that they are unreliable and fall off. As an alternative I would drill a hole and use a pin.
