Go to Post I just... I can't even comprehend it. Like, my brain is soup. Commas are everywhere. Sentences. Shrinking. zzzzzzzzzzzz... - PayneTrain [more]
Unread 26-01-2016, 08:45
sagi34 sagi34 is offline
FRC #2231 (OnyxTronix)
sagi34 is an unknown quantity at this point
Type C Defenses
If you cross a type c defense from the "Courtyard" to the "Neutral Zone", then going back from the "Neutral Zone" to the "Courtyard" leaving the gate open, does it mean you crossed the defense?
Student: 2013 - 2015
Mentor since 2016
Unread 26-01-2016, 08:53
jodge1706's Avatar
jodge1706 jodge1706 is offline
Captain | Driver | Bench Grinder
AKA: Gavin
FRC #1706 (Ratchet Rockers)
Team Role: Driver
jodge1706 is on a distinguished road
Re: Type C Defenses
Your robot has to be completely in the neutral zone and not touching the defense at all. In that time that your off the defense, that gate will most likely close. Now comes into question the "tapping" strategy...
Unread 26-01-2016, 11:17
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Type C Defenses
Or as the event progresses and springs weaken and slow down their recoil rate...
Unread 26-01-2016, 13:05
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: Type C Defenses
I would doubt that this will happen in a time frame where we have to worry about it on an competition weekend. Springs is properly loaded and are not able to push past the elastic limit of the spring, they should last something on the order of 10^6 cycles or more.
Unread 26-01-2016, 13:27
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Type C Defenses
There was a Q&A answer on this subject. The key take away is that it must be obvious to the refs that you were A. completely in the neutral zone and B. not in contact with the defense. So you will not get credit if a ref is not looking at your bot for the moment you were not in contact with the defense.
Unread 26-01-2016, 17:31
rwodonnell rwodonnell is offline
AKA: Rick O'Donnell
FRC #2876 (Devilbotz)
rwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to behold
Re: Type C Defenses
It does look like you can hold the door open, so to speak, for your teammates though.
Q526.
Unread 26-01-2016, 18:17
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
Re: Type C Defenses
Q526.
To me this is the most viable strategy if you don't have a robot that can open it on your own. With could prior coordination and timing you can have one robot hold the defense open and have the other two drive through and damage the defense while you hold the door open.
