Go to Post FIRST isn't about money or robots... it is about people. Take care of that and the rest will follow. - dtengineering [more]
Unread 26-01-2016, 11:32
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Riolog not functioning when connected via wireless to router
I run Riolog from eclipse, and it cannot see the netconsole output. Has anyone else been able to get it to work?
If I run tcpdump, I can see the UDP packets coming from the roboRIO, but they're going to 10.24.23.127, not 10.24.23.255.
It appears that the default settings on the router using the FRC Radio Configuration tool set up two different DHCP pools with different broadcast addresses. Was this intended?
Note: I'm on OSX, but that shouldn't really matter.
Unread 26-01-2016, 12:19
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: Riolog not functioning when connected via wireless to router
We too are not seeing any messages displayed on the RioLog when connected wirelessly. [Note, our laptop is running Windows.] I have not had time to investigate much yet and plan to try it on a system that was able to successfully view messages on the RioLog last year. We do see the messages printed (with both printf and cout) on the DriverStation log when you select "+ Printing" display option.
Unread 26-01-2016, 18:08
virtuald's Avatar
RobotPy Guy
I've exchanged emails with Kevin at FIRST and he believes that he's identified a fix. I expect we'll see an update soon once it has been confirmed.
Unread 26-01-2016, 22:00
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
So it's a good thing the team resisted my suggestion to write messages to STDOUT as a debugging technique....
Software Mentor
3853 Pridetronics[
Unread 27-01-2016, 12:29
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Thanks for the information... I will keep an eye out for the update!
Unread 27-01-2016, 12:40
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We had the same problem, no riolog output. We've taken to ssh-ing to the robot and cat-ing or tail-ing the log file. You can also scp the log file (the name escapes me but you can see the name when eclipse is running the deploy scripts) and save the output.
Unread 27-01-2016, 13:28
virtuald's Avatar
RobotPy Guy
Next time you should report* a bug so it can be fixed?
* Yes, I know there's not a good process to do this...
Unread 28-01-2016, 14:42
virtuald's Avatar
RobotPy Guy
Ok, Kevin says there won't be a Radio tool update until at least next week, so here are instructions you can use to update your radio via SSH if you want this to work now:
  • Radio IP: 10.xx.xx.1
  • Username: root
  • Password: root
Run these commands on the radio once you've SSHed in:
uci set dhcp.lan.dhcp_option=”1,255.255.255.0 28,10.xx.xx.255”
uci set dhcp.wan.dhcp_option=”1,255.255.255.0 28,10.xx.xx.255”
uci commit dhcp
/etc/init.d/dnsmasq restart
Unread 10-02-2016, 21:25
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
has anyone caught wind of when we will see a Radio Configuration Utility update to fix this?
Unread 12-02-2016, 10:20
virtuald's Avatar
RobotPy Guy
Looks like an updated tool was published yesterday: https://usfirst.collab.net/sf/frs/do...ration_utility
