Go to Post Whatever you do though, don't get into an "us versus them" mentality with your mentors. They are there to help. - Bongle [more]
Unread 22-01-2016, 18:56
ejscribner ejscribner is offline
Drive Team & Coach
FRC #2972
ejscribner is an unknown quantity at this point
roboRIO Image mismatch
I am trying to deploy code to my robot and I'm getting the message
BUILD FAILED
C:\Users\Developer\wpilib\java\current\ant\build.xml:208: Assertion failed boolean test.
roboRIO Image does not match plugin, allowed image version: 19
I know that my roboRIO has version 23 on it, and I'm also fairly sure that my plugins are all up to date. So what could be causing this mismatch? Should I just try downgrading the roboRIO image?
Unread 22-01-2016, 19:33
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: roboRIO Image mismatch
BUILD FAILED
It's missing the leading component, you need 2016v19, not 2015v23.
Unread 23-01-2016, 10:01
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Reinstalling tools by closing eclipse, deleting the [your user profile]/wpilib/ directory, then restarting eclipse and letting the plugin copy out the folder again fixed this issue for me.
You can also update the check manually in
wpilib/cpp/current/ant/build.xml
Unread 26-01-2016, 12:18
Drive Team & Coach
FRC #2972
Okay so I figured out the issue: I had to update my National Instruments tools to this years version so that my roborRIO imaging tool had the correct image (v19). Thanks guys!!
Unread 26-01-2016, 13:55
2130Pi 2130Pi is offline
FRC #2130
2130Pi is an unknown quantity at this point
After you reImage the roboRio you have to reinstall the Java JDK and JRE for this year. There is an option in Eclipse to do that.
