Go to Post The culture has shifted, people. You can act shocked and complain, and likely lose the attention of the students you want to reach through FRC and other activities, or you can shift with it, and make FRC relatable and relevant to a bunch of good kids with foul mouths. - mrnoble [more]
Unread 26-01-2016, 08:51
tenspeed78's Avatar
tenspeed78 tenspeed78 is offline
Lead Mentor Team 3487 Earthquakers
FRC #3487 (Earthquakers)
tenspeed78 is an unknown quantity at this point
So, is the team defence platform ramp 12" or 10"?
My team and I were discussing the length of the team defence platform ramp. The question was asked here , but I am still confused on the answer.
The answer said that the field component's technical drawings (CAD) were the ultimate arbiter of the field dimensions, but my question is: Why would they give us two different dimensions?, changing the angle of the ramp by two inches and a degree of slope is kind of a big deal. They site "ease of construction", nothing is easy about giving us conflicting sizes for critical field objects. Below are the conflicting images I am referring to, the first is from the game manual, the second is from the CAD drawings.
What is the length of the ramp? What is the angle of the ramp?
ID:	19882  Click image for larger version
Unread 26-01-2016, 09:01
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: So, is the team defence platform ramp 12" or 10"?
We found the answer is: they're the same. The team versions ramp is 1/2" thick, while the field version is 1/4. Draw both ramps with the top (left say) corner starting at 3" above the floor and the bottom right corner touching the floor, and you'll see the top surfaces are nearly collinear at about 13.5 degrees. The plywood just has a thicker leading edge.
Edit: On second read - I see you aren't talking about the team versions, but the difference between the field drawings and the manual. That difference seems pretty minor to me (the 11.75 gets pretty close to 12" once you include assembly gaps, but I'll let others chime in.
Unread 26-01-2016, 12:18
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Drawings trump whatever the manual says.
Unread 26-01-2016, 12:26
tenspeed78's Avatar
Then the drawings and the manual should be the same dimensions...Am I crazy for expecting the game manual and the actual field dimensions to be the exact same?
Here is what I found so far:
1. Game manual ramp length = 12"
2. "Build it yourself" CAD drawing ramp length = 10.75"
3. Field Object CAD drawing ramp length = 11.75"
4. ???
It seems like it would have been much less confusing to just dimension all ramp depictions to be 11.75"....sigh
Unread 26-01-2016, 12:33
cgmv123's Avatar
AKA: Max Vrany
The manual explicitly says the official field drawings supersede whatever nominal dimensions are in the manual.
4. ???
The team version drawings aren't intended to be exact. Being an exact duplicate of the competition field is sacrificed in favor of being able to be built easily by teams.
