Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 26-01-2016, 14:23
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
amstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to behold
Can't connect to new DLink
I am using our new OM5P-AN dlink, but I can't connect because it won't even appear as an option to connect to. Usually if I had this problem in the past, I would reset the DLink, but there seems to be no manual reset on the new DLink. Any help appreciated!
Unread 26-01-2016, 14:43
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: Can't connect to new DLink
Are you sure it is plugged into the 12V port on the voltage regulator module?
461 Westside Boiler Invasion
45 Technokats
Unread 26-01-2016, 14:56
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Check out this link for instructions that you may find helpful. The only way to reset the new radio is to use this tool.
http://wpilib.screenstepslive.com/s/...o-for-home-use
-Hugh
Unread 26-01-2016, 14:53
DAlitz's Avatar
DAlitz DAlitz is offline
AKA: Dave Alitz
FRC #3042 (Cobalt Catalysts)
Rookie Year: 2016
DAlitz is an unknown quantity at this point
The OM5P-AN replaces the DLink for 2016 -- calling it the DLink might cause some confusion.
Have you run the FRC configuration program? Until you configure the OM5P-AN it's not set up for your team.
If it's not from the KOP you'll have to update the firmware to the custom FRC firmware. Check under New for 2016 in the Getting Started... documentation:
https://wpilib.screenstepslive.com/s/4485
I think this will take you directly to the right place:
https://wpilib.screenstepslive.com/s...anual-id=13503
