Re: Bridge configuration failed on OM5P-AN radio
Our team worked for several hours to use the Radio Configuration Utility last night and I thought I'd share our solution in case it helps other teams.
When we attempted the steps from the FRC documentation, screenstepslive.com, we ran into the same problems described in this thread. Our team member, Henry, discovered the solution which turned out to be two problems. The first is running the configuration tool as Admin. The second is properly disabling the wifi interface. First, in order to conform to best security practices we have our driver station laptop set up with a admin account and an underprivileged user account that has the FRC software loaded onto it. However, the configuration utility must run as admin in order to change IP addresses. So we had to right click on the application and select "Run as administrator" when we launched the Radio Configuration Utility. Second, we were getting the errors everyone else is talking about on this page that Henry discovered were caused by the wifi interface not being disabled properly. What makes this tricky is that the graphical icons in in the Windows 10 control panel are NOT intuitively clear. The first preliminary step in the link above states, "Disable WiFi connections on your computer, as it may prevent the configuration utility from properly communicating with the bridge." So, in the image below you would think the big red "X" next to the Bluetooth interface would mean that it is disabled. BUT THE RED "X" DOES NOT MEAN THE INTERFACE IS DISABLED. In order for the interface to be disabled it has to be "greyed out" like you see the Wi-Fi interface in the image above after we solved the problem. In order to get more clarity I think the command prompt is much clearer. Open a command prompt window and type Code:
netsh interface show interface So....in order to get to this state use the Windows GUI to start at the control panel and follow this link chain: Control Panel ->Network and Sharing Center -> Network Connections. Then right click on the Wi-Fi interface and make sure you select "Disable". You can run the command prompt again to confirm the correct state. After these steps we were able to upload the radio firmware and continue our build. Good luck out there this year. I'm really looking forward to watching teams play Stronghold. This is gonna be great! |
