Go to Post YES!!!!!! I read this and jumped! This is awesome and amazing! Thank you so much Dean Kamen and FIRST!!! YOU ARE AMAZING! - torihoelscher [more]
Unread 26-01-2016, 16:20
Pyro_84 Pyro_84 is offline
FRC #1769
Pyro_84 is an unknown quantity at this point
Changing individual Drive motors output
One of the motors in our drive system doesn't seem to rotate as fast as the others. I was wondering if there was any way to change the output of individual
motors through the code.
I've gone into the open drive motors vi, inside I saw that the pwm channels were separate, but I don't know if I can change these individually.
Any suggestions?
Unread 26-01-2016, 16:23
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Changing individual Drive motors output
Any suggestions?
This is probably a calibration issue with the motor controller. Have you calibrated all of your motor controllers?
Unread 26-01-2016, 16:27
FRC #1769
Do you mean the talons, or jaguars. If so I'm not entirely sure how to do that.
Unread 26-01-2016, 16:31
Flywheel Police
They are both motor controllers.
Which talons are you using?
Unread 26-01-2016, 16:32
FRC #1769
actually we are using jaguars
Unread 26-01-2016, 16:34
Flywheel Police
There is a button on the Jaguar that you'll push with a pin. Hold that button down then apply full forward power to it using the joystick, then reverse full power, then let the joystick go. After all of that release the button you were holding.
Unread 26-01-2016, 18:23
FRC #1769
Thank you for your help
