Go to Post I'm gonna go back to my corner and write some more code... - Kevin Watson [more]
Unread 24-01-2016, 00:40
alo098 alo098 is offline
FRC #2473
alo098 is an unknown quantity at this point
Carabiners and hooks
Hi FIRST Participants!
Just wondering what ideas some other teams had for hooking on to the tower pull up bar. Our team has looked into carabiners, but we havent found one large enough or that is weighted. As of now, we are looking at using a steel hook or making ine from fiberglass. We would really appreciate any ideas or suggestions!
Unread 24-01-2016, 01:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Carabiners and hooks
Check boat and dive shops. Mariners have invented all sorts of neat ways to put a line on a rung. There's even one called the "happy hooker" that basically threads the needle for you. It has a piece that toggles back and forth between two pivots, and the bottom line is that you just have to push the hooker across the rung and pull it back, and you've threaded the rung and are pulling back the bitter end. A bit pricey, but very cool, and reliable as well.
Unread 24-01-2016, 03:51
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
If you have a CNC or basic mill this kind of clip is a good option. We plan on doing something similar, but somewhat different. It's basically an oversized gate latch.
Unread 24-01-2016, 15:39
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Carabiners can work, but you need a person to reach the clip to unhook it at the end of the match. The gate latch or other hook that can be released from a line or stick is best bet.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 24-01-2016, 16:53
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
I don't think they generally make climbing carabiners that size, but even if you could find one you would have a problem, carabiners that size would be for some heavy duty mountaineering, as such the have a latch on the opening portion, so that it cannot be pushed open, but rather you have to rotate a screw to unlatch it. Also those types of carabiners are built to withstand the force of a person falling at several meters per second stopping suddenly, so they are large and made of very heavy duty (and heavy weight) material, which could cause a problem for a robot with a strict weight limit
Unread 24-01-2016, 17:37
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Carabiners and hooks
http://www.rescuetech1.com/iscfiremansladderhook.aspx
Used to hook on ladder rungs.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 24-01-2016, 18:14
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Back in 2010 to climb we placed a custom aluminum hook above the bar using a telescoping PVC arm. We then retracted the arm, leaving the hook on the bar, and then winching ourselves up with a cable.
In 2013 we made two custom spring loaded latch mechanisms to grip on to the 10-point bar of the pyramid from below. The latches were extended and retraced with 2 pneumatic cylinders.
ID:	19868  Click image for larger version
Name:	4479101234_719004cda3_b - Copy.jpg
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 24-01-2016, 22:11
Team Role: Driver
Originally Posted by Scott L. View Post
see, its got a block / stopper that you have to unscrew or twist to open the gate, making it hard for a robot to use
Unread 24-01-2016, 22:37
I think I can bypass that. It's actually not all that hard. All you have to do is stop the lock from engaging, and that could be done with anything from taping it back to putting a pin or setscrew through the lock to completely removing it.
That being said, if you do do something stronger than tape, I would also suggest that after the robot is totally scrapped the carabiner should probably be pretty thoroughly labeled/physically damaged so it won't be used for climbing.
Unread 26-01-2016, 17:14
FRC #2473
Thank you mentors and fellow students for all your help and ideas! We really appreciate it.
Unread 26-01-2016, 18:20
RoboChair's Avatar
AKA: Devin Castellucci
We have used Harbor Freight carabiners in 2013 to hang from a similar sized bar, we just cut them to size to make them work.
http://www.citruscircuits.org/upload...08317_orig.jpg
You could make that easily with a drill, some quality time with a hacksaw, and a little love with a file.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 26-01-2016, 18:29
Weinberger's Avatar
Weinberger Weinberger is offline
FRC #1683 (Techno Titans)
Weinberger is an unknown quantity at this point
Something like this? From rock climbing; the stick clip
http://m.instructables.com/id/Rock-Climbing-Stick-Clip/
Unread 26-01-2016, 19:42
Scott L.'s Avatar
Lightbulb Re: Carabiners and hooks
http://www.trango.com/p-245-squid-the-unclip-stick.aspx
