Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
Unread 26-01-2016, 17:22
Abelbae Abelbae is offline
FRC #5784
Abelbae is an unknown quantity at this point
Question Pneumatics Control Module Requirement
This year, our team is not using any pneumatic devices in any of our systems. So, do we need to have a pneumatic control module on the robot, or can we take it off? I'm asking this see if we can save space, and eliminate another device from the CAN chain.
Unread 26-01-2016, 17:35
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Pneumatics Control Module Requirement
Yes you can take it off, you do not have to have the PCM if you are not using pneumatic.
Omar
Unread 26-01-2016, 17:47
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If you are not using the module, you can leave it off.
