Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 26-01-2016, 17:44
alexusaywla alexusaywla is offline
AKA: Alexus
FRC #6155 (ElektraBots)
Rookie Year: 2016
alexusaywla is an unknown quantity at this point
Red face Beginning Programming
I have the WPILib file with all the packages installed in Eclipse. How can I actually start programming the robot? I thought I'd use the WPILIb code but when I open each package it doesn't allow me to edit anything. I'm assuming I shouldn't be doing this. Can someone please explain to me as to how to actually start programming?
UPDATE: I opened the src file and now I am in the Robot.java class... Should I be here instead?
Unread 26-01-2016, 17:49
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Beginning Programming
Go here http://wpilib.screenstepslive.com/s/4485
Click on the language of choice, then look for Creating and Running Robot Programs (or something very close to this)
These links will walk you thru the steps to create a program for your robot
The views expressed are mine and should not be construed to represent the views of anyone else.
