Go to Post Possibly the most amazing thing all week was that this game can be played with mecanum wheels. - fargus111111111 [more]
Unread 26-01-2016, 18:26
iSpotix iSpotix is offline
FRC #4049
iSpotix is an unknown quantity at this point
[Vision] Multithreading?
What is the best way to have a vision loop that constantly updates numbers, but with a short sleep period but not hinder the normal teleop loop?
If I want to update the numbers every half second or so is there a way I can do that without making the whole teleop loop wait? I've looked at Runnables, but is there an easier way to do this?
Unread 26-01-2016, 18:39
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: [Vision] Multithreading?
as long as you're sure that this is what you want to do..
new Thread("Vision Processing Thread"){public void run(){
    while(true){
         camera.process()
         try{
               sleep(500);
         }catch(Exception e){}
}}.start()
(apologies if syntax errrors i wrote this in the texte ditor)
Unread 27-01-2016, 09:34
FRC #4049
Is there a better way to do this? What is the normal way to include vision processing?
Unread 27-01-2016, 21:41
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Something like this might work for you:
// Create a new Timer to schedule vision processing
Timer visionScheduler = new Timer("Vision Scheduler", true);
void doVisionProcessing() {
    // Your vision code here
public void autonomousInit() {
    // Perform vision processing every 50ms, starting in 0ms (i.e. now)
    visionScheduler.scheduleAtFixedRate(new TimerTask() {
            public void run() {
                doVisionProcessing();
        }, 0, 50);
Keep in mind that you'll need to do the normal threading stuff like locks/synchronization blocks and declaring shared variables volatile, but that applies for any multithreaded program.
WPILib
GRIP, RobotBuilder
Unread 29-01-2016, 11:15
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
Otherwise you could put it in a periodic method.
2013-2014: Electrical, Mechanical
2014-2017: Team Captain
Unread 29-01-2016, 11:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have a utility in our github to do this. Send an e-mail to gixxy if you have any questions (he doesn't check CD daily).
Unread 31-01-2016, 18:24
JacobD's Avatar
AKA: Jacob
Thread cameraThread = new Thread()
	public void run()
		//camera code goes here
Then do...
cameraThread.sleep(timeInMillis);
or
cameraThread.stop(); //not sure if this is depreciated
java.util.Timer myTimer = new java.util.Timer();
myTimer.schedule(new TimerTask()
       @Override
	public void run()
		 cameraThread.run();
}, 1000);
The difference between this and sleeping the thread is that the timer doesn't suspend the run-time of the program. I'm thinking that this is what you are looking for.
Unread 05-02-2016, 03:26
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
We have a vision target module in our library that will take care of the multi-threading stuff. It spawns a separate thread and will process each frame to look for objects for the specified criteria. If a new frame is processed, the new result will overwrite the old one. In other words, we always have the latest result cached. If the main robot thread wants to look for "targets", it gets the cached result from the vision targeting thread.
Unread 05-02-2016, 06:45
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
We have it running as a separate program on the Driver Station. We use Network Tables to communicate with the RoboRio. It grabs the same picture that is being displayed on the DS for the driver.
when "picture" is 0, the vision program does nothing.
When "picture" is 1, it starts vision processing, and changes the value to "2" to indicate it is working.
When it is done calculating, it sets "Angle", and "Distance", and changes "picture" back to 0.
On the RoboRio, it waits for "picture" to go back to "0". when it sees that, it takes "Angle" and "Distance" and drives there (using NavX).
Rinse, repeat, until Angle and Distance are close enough to shoot.
