Go to Post Semi-colon cancer -- the disease received after spending too much time writing lines of programming code - nehalita [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 26-01-2016, 19:26
nhalstead's Avatar
nhalstead nhalstead is offline
Noah H
FRC #5420 (Velocity)
nhalstead is an unknown quantity at this point
Question Bumper and Min + Max
On page 59 Figure 4-3 is Showing Figure C (Bottom Left) it is showing that "Not a Bumper" and "Not Ok" are not correct... So for "Not Ok" is showing that you do not need to have the bumper that long, Then for "Not a Bumper" you do not need to have the Bumper in the inside of the robot.
Am I understanding this correctly?
I do understand that you will need to cover all of the corners of the frame. Also I remember that other years they had bumpers but I do not know what the rules were for that.
Unread 26-01-2016, 19:31
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Bumper and Min + Max
First off, rules from previous years don't apply. Only the one in the 2016 FIRST Stronghold manual apply.
The "Not okay" pointing to the bumper is because that bumper is less than 8", therefore not adequate cover for the corner of the side.
You are correct about not needing bumpers inside of your frame perimeter, only at least 8" of exterior corners.
Academic Student (Forever)
Unread 26-01-2016, 19:35
Well... sort of.
Not a Bumper: There is nothing saying that you can't have a structure in there that is built like a Bumper. However, you cannot count it as a Bumper. It won't count towards the 8". The reason is that it's not on the Frame Perimeter.
Not OK (bottom): There isn't a bumper there, and there needs to be 8" of bumper because it's next to a corner of the Frame Perimeter.
Not OK (right): It's "Not OK" because the bumper is too short (< 8"), and the frame it's mounted to is too short for a full bumper, but the Frame Perimeter is clearly longer than 8".
Bear in mind I'm looking at the most recent version of that image, which was in today's Team Update.
Unread 26-01-2016, 19:47
nhalstead's Avatar
Noah H
Correct?
Unread 26-01-2016, 19:50
That looks like the right image. So the "Not OK" flags are for no bumper where there should be one and a bumper that is too short (and on a frame section that is too short to support a full 8"+ bumper).
Unread 27-01-2016, 09:14
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not a bumper also means that it is part of the robot for the purposes of weight, costing, bag & tag rules, and so on.
Unread 27-01-2016, 19:06
coachm's Avatar
coachm coachm is offline
Coach
FRC #3865 (Riley Robotics)
coachm will become famous soon enough
Cool Re: Bumper and Min + Max
This may be a stupid question, but...
We don't have to bag and tag the bumpers, right? Do they count towards your withholding allowance??
Thanks!
Unread 27-01-2016, 20:47
Knufire Knufire is offline
Thanks!
Nope! They were redefined fairly recently (2014?) to not be part of the robot, and therefore not subject to the various robot building rules.
BUMPER a protective assembly designed to attach to the exterior of the ROBOT and
constructed as specified in Section 4 (4.7 BUMPER Rules)
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 27-01-2016, 21:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Thanks!
Bumpers are excluded from both.
Originally Posted by R15
All ROBOT elements (including items intended for use during the competition in alternative configurations of the ROBOT), with the exception of the WITHHOLDING ALLOWANCE per R18, BUMPERS, and COTS items, must be bagged and sealed, by 11:59PM local time on Stop Build Day, February 23, 2016 (refer to the Admin Manual Section 5 (5.3 Bag and Tag and Robot
Transport to Regional/District Events).
