Go to Post You worry about your team. Let other people worry about their own teams. - pfreivald [more]
Unread 26-01-2016, 19:54
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
6 CIM motors max, but unlimited AndyMark Bane-Bot motors
Just want to be sure we are reading R29 correctly. We can legally have unlimited AndyMark Bane-Bot motors, right?
Unread 26-01-2016, 20:08
Colin935's Avatar
Colin935 Colin935 is offline
FRC #0935
Colin935 is an unknown quantity at this point
Re: 6 CIM motors max, but unlimited AndyMark Bane-Bot motors
Yes, but the roboRio only has 11 PWM's so after 6 cims you can have maximum 5 banebots.
Unread 26-01-2016, 20:10
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Colin935 View Post
Yes, but the RoboRio only as 11 PWM's so after 6 cims you can have maximum 5 banebots.
You can definitely run more than 11 motors on a robot, or even more than 11 unique PWM outputs. This is not a hard limit on the number of motors on the robot and shouldn't be stated as such.
Unread 26-01-2016, 20:15
FRC #5523
Good point. Thank you.
Unread 26-01-2016, 20:16
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
You could always utilize CAN instead of PWM.
Your upper limit is going to come from the available number of WAGO slots on your PDP.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 26-01-2016, 20:17
ccresta1386's Avatar
ccresta1386 ccresta1386 is offline
AKA: Collin Cresta
FRC #4954 (Palindrome Robotics)
Team Role: Driver
ccresta1386 is an unknown quantity at this point
Yes, but if they do need more there is always the More Board, though if you are running too many motors you run the risk of a brownout.
Link to the More Board: http://www.andymark.com/product-p/am-2995.htm
Unread 26-01-2016, 20:18
FRC #5523
That is a great thought. How would that work? Would I need a second RoboRio? a second Power Supply panel?
Unread 26-01-2016, 20:20
FRC #5523
Thanks for the link. Very helpful. Wow, we have a lot to learn...
Unread 26-01-2016, 20:21
AKA: Matt B
FRC #1771 (1771)
I'd suggest you re-read this document: https://firstfrc.blob.core.windows.n...-manual-04.pdf
Pay attention to rule R56 and R36.
1771- Mentor (2015)
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Full size CIM's are the only motor that has a 'limit' this season.
This is not related to the limit, but Andymark does not actually have "Bane-bots" motors, are you talking about the 550 style 9015 or the Andymark PG 775 motor.
It is important to note that the Andymark Planetary Gearbox with 775 motor is not a banebots RS775-18 and is a Andymark RS775-125 which is very weak in comparison to the Banebots or WCP 775 motors. It has less than 20% of the output power of the RS775-18.
Unread 26-01-2016, 20:23
AKA: Pinecone
You can also use PWM Y-Cables to connect multiple speed controllers receiving the same signal. All of the motors on the same gearbox should probably be connected to speed controllers connected via PWM Y-Cables. This saves on the number of ports you need to use.
Unread 26-01-2016, 20:26
FRC #5523
Thanks so much for the guidance. So, I see that only ONE power supply and ONE RoboRio is allowed. So it looks like either the MORE board or the WAGO slots is the way of increasing the number of motors?
Unread 26-01-2016, 20:28
FRC #5523
That's right. I forgot about the y-connectors. Thank you.
AKA: Matt B
FRC #1771 (1771)
The WAGO slots on the PDP are the "ports" that you plug your motor-controller wires into.
You can not (FRC-legally) modify the PDP to have more WAGO slots. The MORE board allows you to have more PWM outputs, but won't actually give you more WAGO slots.
Edit:
As to your question about the "Y" connector:
Yes you could do that. Make sure that each CIM motor is connected to it's own motor controller, and each of those motor controllers are connected to different WAGO slots.
Keep in mind, whatever PWM signal you send into the "Y" cable will be sent to both. You can't address each motor controller individually that way. So make sure that the motors spin the correct directions and aren't fighting each other once inside the gearbox.
1771- Mentor (2015)
Unread 26-01-2016, 20:29
AKA: Collin Cresta
Team Role: Driver
That's right. I forgot about the y-connectors. I can "y" the two CIMs running the same mini-gear box right?
Yes, You can since the motors will always have to go in the same, direction and power.
