Go to Post There are two types of team members and mentors: Those who want to be FIRST, and those who want to be first. - Tetraman [more]
Unread 26-01-2016, 20:18
Cobra Commander's Avatar
Cobra Commander Cobra Commander is offline
FRC #0498 (Cobra Commanders)
Cobra Commander is on a distinguished road
Re: GRIP with USB Camera
Originally Posted by SLAB-Mr.Thomas View Post
GRIP on the roboRIO with our USB Lifecam 3000-HD works without camera error...
Do I still initialize the camera server when trying to use it with grip?
CameraServer server = CameraServer.getInstance();
		server.setQuality(50);
		server.startAutomaticCapture("cam1");
Unread 26-01-2016, 20:36
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
If you initialize the cameraserver in your robot program GRIP probably won't be able to access it. Usually only one application can access a camera at a time on Linux.
To get similar functionality as CameraServer, you can use the "Publish Video" operation in GRIP.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 26-01-2016, 20:52
I think we are really close to getting this working!
What is setting property #16?
We are getting this error on our deploy:
Jan 27, 2016 1:53:36 AM edu.wpi.grip.core.Main start
INFO: Loading file /home/lvuser/project.grip
VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP
VIDEOIO ERROR: V4L: setting property #16 is not supported
Jan 27, 2016 1:53:40 AM edu.wpi.grip.core.Main start
INFO: SUCCESS! The project is running in headless mode!
Unread 27-01-2016, 00:54
FRC #0237
Looking at the OpenCV source code, it seems like it has a lot of video capture properties available for V4L (the Linux video capture API), but most of them are only supported with V4L 2. If you're using V4L 1 and you try to set any property besides the few that are supported, OpenCV prints an error message
This is completely harmless. Since we don't do anything to manually configure camera settings in GRIP, any properties that get set are just by OpenCV trying to set up some defaults.
Is the project working otherwise? I noticed you have a SUCCESS message and no exceptions.
Unread 27-01-2016, 22:55
Yes! Everything appears to be working. I saw the error an I guess I panicked.
Everything appears to be operational, network tables and all.
Should I be concerned about this error? Everything seems to still work but, maybe.
Loading Dependency Injection Framework
Jan 28, 2016 3:48:21 AM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
Jan 28, 2016 3:48:22 AM java.util.logging.LogManager$RootLogger log
CONFIG: GRIP Version: 1.1.1
platform: /Linux/arm/
Jan 28, 2016 3:48:28 AM edu.wpi.grip.core.Main start
Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: Input must have a value to run this step.
SEVERE: Value must have a value to run this step.
Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionClearedEvent
INFO: Exception Cleared Event
Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main onExceptionClearedEvent
Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main start
It says the image must have a value but, it appears to be getting an image from something.
Unread 27-01-2016, 22:57
FRC #0237
While the project is loading, the steps start running before the camera is ready. This isn't really concerning, and it should be fixed in the next release.
Unread 28-01-2016, 08:15
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
Hi Thomas I am still not able to get my camera (Microsoft 3000 USB) to be found in version 1.1.1. Every time I enter 0 the error pops up "A problem occurred trying to start the frame grabber for Webcam 0". I know this camera works do testing it on the robot and on other computers that have the older version of Grip on them.
Sincerely,
Joe
Unread 28-01-2016, 10:25
FRC #0237
Can you try it on the other computers with a newer GRIP? AFAIK nothing has changed with USB cameras between the last few versions of GRIP, so it may be a driver issue.
Unread 28-01-2016, 12:20
Crossle86's Avatar
Crossle86 Crossle86 is offline
Software Engineer
AKA: Richard Corn
FRC #4450 (Olympia Robotics Federation)
Crossle86 is an unknown quantity at this point
We did this but the feed to the DS was very slow, too slow to be useful.
Also, we have code that uses the NI camera support to switch the DS feed between multiple USB cameras...but we can't use it if GRIP is running. Is there some way or could a way be added for the robot code to feed images to GRIP instead of GRIP commandeering the camera? We are interested in GRIP but do not want to give up our existing camera server code.
Unread 28-01-2016, 16:14
FRC #5712
Figured it out that the drivers of the camera had not been fully downloaded. Thanks for your help.
Unread 30-01-2016, 11:20
pluto7443 pluto7443 is offline
FRC #4917
pluto7443 is an unknown quantity at this point
Hey, so we are having some issues with getting the network tables to work. I was wondering if you guys who got it working could elaborate on how you got that side of things working? We're using C++.
Thanks!
Unread 21-02-2016, 19:59
s-taylor s-taylor is offline
Scott Taylor
FRC #1735 (Green Reapers)
s-taylor has a spectacular aura abouts-taylor has a spectacular aura about
Hi, all.
My problem is similar to others in the thread, but not quite the same.
I can get GRIP 1.2.0 running just fine on my laptop, using the MS Lifecam 3000 USB. it publishes to NetworkTables on the RIO, and then the DS is able to act upon it to control the robot as expected.
So far, so good.
But when trying to deploy the GRIP to the robot (so it can run headless on the RIO), I get this error:
/usr/local/frc/JRE//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip'
Jun 05, 2015 8:40:12 PM java.util.logging.LogManager$RootLogger log
CONFIG: GRIP Version: 1.2.0
Jun 05, 2015 8:40:17 PM edu.wpi.grip.core.Main start
Jun 05, 2015 8:40:19 PM edu.wpi.grip.core.Main start
Jun 05, 2015 8:40:19 PM edu.wpi.grip.core.PipelineRunner$1 startUp
INFO: Pipeline Starting
OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp, line 3208
Jun 05, 2015 8:40:19 PM edu.wpi.grip.core.Step runPerformIfPossible
WARNING: The CV resize operation did not perform correctly.
java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize
	at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method)
	at edu.wpi.grip.generated.opencv_imgproc.Resize.perform(Resize.java:58)
	at edu.wpi.grip.core.Operation.perform(Operation.java:61)
	at edu.wpi.grip.core.Step.runPerformIfPossible(Step.java:139)
	at edu.wpi.grip.core.PipelineRunner.runPipeline(PipelineRunner.java:196)
	at edu.wpi.grip.core.PipelineRunner.access$200(PipelineRunner.java:32)
	at edu.wpi.grip.core.PipelineRunner$1.runOneIteration(PipelineRunner.java:76)
	at com.google.common.util.concurrent.AbstractScheduledService$ServiceDelegate$Task.run(AbstractScheduledService.java:189)
	at com.google.common.util.concurrent.Callables$3.run(Callables.java:100)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Note no startup errors prior to the ssize.area() error.
I do start GRIP from RobotInit as specified:
        /* Run GRIP in a new process */
       try {
            new ProcessBuilder("/home/lvuser/grip").inheritIO().start();
        } catch (IOException e) {
            e.printStackTrace();
I've tried rebooting the RIO prior to deploying, just in case some other instance of GRIP was already running.
I also made sure the CameraServer is not running.
I'm GUESSING that the camera isn't sending any images to the first pipeline stage (resize)... but there's insufficient debug info in the log to tell me what might be wrong.
I checked that the GRIP file is using device 0, and this matches what is in the RIO dashboard (which says "cam0").
Thoughts?
-Scott
Unread 21-02-2016, 23:34
FRC #0237
I would agree with that. The camera is sending "empty" 0x0 pixel, 0-channel images, probably because it didn't initialize correctly. A few other people have had basically the same problem, so we've been trying for the past week to reproduce this, but we haven't got it to happen with at least an actual error message about the camera.
One this I would recommend trying out is the v1.3 release candidate 1. The only thing it changes about cameras is that they now try to restart if they don't work the first time. The problem might be as simple as cameras not connecting the first time because they're initializing or something weird.
Let me know if this helps.
Unread 22-02-2016, 08:55
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
THANK YOU! Been waiting for command line arguments for a long time!
Unread 22-02-2016, 10:32
Scott Taylor
Thanks, Tom! I'll try installing that tonight.
BTW, we are finishing our build season in the WPI pits (since we don't have access to Burncoat HS during winter vacation)... so we will be on campus tonight from 6-10 if you happen to be around and want to see an instance of this issue "live". My email is s-taylor@att.net if you want to contact me outside of this thread.
