Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
Unread 26-01-2016, 20:55
grainne grainne is offline
Lead Programmer
FRC #0811 (Team 811 Cardinals)
grainne is an unknown quantity at this point
global variables?
Hi
So my team's shooter for the boulders is done with a spinning wheel and has a conveyor belt that brings the boulder up to it. However, we do not want the boulder to be up at the spinning wheel until it is at full speed.I am trying to have a global boolean that will turn true when the shooter is full speed and allow the conveyor belt to bring the boulder up to it. However,I don't know where to put this. Our project has a config file, but any variables initialized in there cannot be changed as the program runs.
Any ideas as to where to put this boolean so it can be accessed and changed by multiple subsystem?
Unread 26-01-2016, 22:33
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: global variables?
Originally Posted by grainne View Post
Hi
i'm just going to assume you're using command based:
you could add this in your shooter subsystem:
public boolean IsAtFullSpeed(){
return velocity >= x;
where x is the speed you need to achieve
and use it in your conveyor subsystem:
if(robot.shooter.IsAtFullSpeed()){
shootBall();
Edit: if you want to modify a global variable, (in this case i'm using myBoolean)
you need a getter and a setter method.
public boolean getBool(){
return myBoolean;
public void setBool(boolean value){
myBoolean = value;
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 27-01-2016, 14:21
Lead Programmer
awesome! thank you so much!
