Go to Post How do You Chiefdelphi? :cool: - SpaceOsc [more]
Unread 26-01-2016, 21:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Position control of pistons with simple solenoids
Just remember: Air is compressible. Put a load on your cylinder shaft and it will move.
In general, it is a best practice to use pneumatic cylinders for two positions only.
Unread 26-01-2016, 21:51
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
I don't know if you want to control the cylinder along a continuous length, or only have discrete points you want to reach. However, if you simply have more that two discrete points you want the cylinder to actuate to, there are a couple options. First, there are multi-position cylinders available, which may be a viable option. I have also seen teams successfully attach one cylinder to the end of another, such that two separate cylinders combine to be able to reach four different points. I would imagine that, given enough creativity, one could even stack two three-position cylinders together, or a few two-position cylinders, though this may require more custom parts, time, or weight. That being said, it is certainly a viable option if you don't need a continuously variable position.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
