Go to Post I don't remember ever having "attack of the jumbo ball" in FRC! - Beth Sweet [more]
Unread 26-01-2016, 21:45
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
Intake and Shooter (Flywheel) Motors
Hello everyone,
This year I have noticed many teams have decided to prototype, and even fully develop their boulder intake methods to include a roller or rolling wheels of some type. I have also noticed that many teams have been trying out flywheel shooters.
So my questions to you are:
1.
If you are using a roller/wheel driven intake mechanism, what kind of motors/gearboxes will you be using?
2.
If you are using a flywheel setup, what kind of gearbox and motor combination do you intend on using to launch boulders?
My team is strongly considering the aforementioned mechanisms, and want to collect some general information on the ideas.
Thank you!
Unread 26-01-2016, 21:55
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: Intake and Shooter (Flywheel) Motors
For intakes I highly recommend 775 motors with banebots p60 gearboxes (5:1)
For shooters I would use a naked miniCIM.
Hope this was helpful!
It isn't shiny enough.
Unread 26-01-2016, 22:05
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
I would personally recommend using Versa-Planetary Gearboxes for both systems, as they give you the ability to fine tune gear ratios and thus output speeds quickly and easily.
Versa-Planetary's with 775pro motors or BB RS775-18's should be good for both. The gear ratios obviously depending on what size shooter/intake wheel etc.
Something else to consider is that you probably want an encoder of some sort on the shooter, so you get consistent shooting distance. The Versa-Planetary has a encoder stage available this year, which might be helpful for this.
