Go to Post FIRST is not about building robots, it is about building people; the robots are just a good way to get the people there. - JamesBrown [more]
Unread 25-01-2016, 23:50
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Best Way to remove double sided tape.
We used double sided tape last year to stick down all of the components of the control system. We have to reuse the system, so what's the best way to remove the double sided tape cleanly and easily. (The tape is super super sticky/strong).
Unread 25-01-2016, 23:52
nighterfighter nighterfighter is online now
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Best Way to remove double sided tape.
You could use a knife to peel it off, then a small amount of diluted rubbing alcohol, on a q-tip, to get the residue off.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 25-01-2016, 23:54
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Will isopropyl alcohol do the job?
Unread 25-01-2016, 23:55
Turing'sEgo Turing'sEgo is offline
Turing'sEgo can only hope to improve
If you can somehow apply Acetone to it, that would do the trick.
Unread 25-01-2016, 23:56
AKA: Matt B
FRC #1771 (1771)
They are the same thing. Rubbing alcohol usually refers to 70% isopropyl alcohol.
I'd make sure you wipe it off once you are done also, just to make sure it doesn't linger and eat through the plastics.
1771- Mentor (2015)
Unread 25-01-2016, 23:58
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Got it. Thanks.
Unread 26-01-2016, 00:04
Dennis5045's Avatar
Dennis5045 Dennis5045 is offline
AKA: Dennis Taylor
FRC #5045 (SpartaBot)
Dennis5045 is an unknown quantity at this point
Goo Gone works wonders on adhesive.
Unread 26-01-2016, 00:05
More likely to eat plastic, though, in my experience.
Unread 26-01-2016, 00:09
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
That's exactly what i was thinking. I thinking isopropyl alcohol should be good enough, and I don't think it'll eat the plastic.
Unread 26-01-2016, 00:31
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
I have had lots of success with WD40 and removing various adhesives.
I would stay away from alcohol. Different types of plastics do not react well with isopropyl alcohol.
Depending on where and what you are removing. Try using a wooden artists knife (toothpick, chopstix, etc.) and put some WD40 on the tape and work the two parts apart. Adding more WD-40 as needed.
Good luck!
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 26-01-2016, 09:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The best idea is to only use 3M VHB in the first place. It comes off clean. I know that doesn't help your current situation, but it may save you in the future.
We recently has to take some vinyl (like car window vinyl) off a toolbox. Mineral Spirits was the only thing that did the trick without removing paint. Long working time too.
Unread 27-01-2016, 01:44
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
If you can use a heat gun to apply heat to the surface material (from below) that you want the tape to come clean from, then do that and apply light tension pulling it away at a 90º angle from the surface. Avoid too much heat hitting the tape itself. The idea is to lower the viscosity of the adhesive, at the bonding layer only, to increase its elasticity there and reduce its peel strength.
Once softened, it must be peeled SLOWLY, and you must watch the adhesive stretching as it lets go, to regulate the force you apply! Too rapid peeling will leave more adhesive residue on surface you want to be clean.
If selective patches of adhesive remain stuck to surface you want clean, then dab the removed tape face's adhesive back against the surface a few times to re-bond the remaining patches over onto to the removed adhesive. They should stick preferentially to the removed adhesive tape face more so than to the surface being cleaned, and just by the number of press and remove cycles, nearly all residue should gradually let go, and transfer over to the removed tape face.
It is a process that requires patience to end up with the best results.
If the heat can only be applied to the tape side, and pass through the tape to reach the surface, the heating must be done much more gradually, bucause if the tape is much hotter than the surface, the adhesive will tent to release from the tape sooner than from the surface. Works best when surface is warmer than the tape, or at least they are equal.
However, heat can be applied from tape side , as long as it is done more gradually, allowing enough time for heat to conduct through the tape. Foam tapes act like insulators, so they need even MORE gradual heating (or baking) time if you must heat the surface below from the tape side via a heat source conducting through the tape.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 27-01-2016, 14:27
thiensonho's Avatar
thiensonho thiensonho is offline
FRC #3735 (Klein Bots)
thiensonho is an unknown quantity at this point
WD-40 works wonders from our team's experience. Spray some on the adhesive and rub hard with your thumb and it should peel off fairly easily.
Unread 27-01-2016, 16:15
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
DON'T do this. Acetone can weaken the plastic, and cause structural failures. I've watched a piece of 1/4" Lexan rubbed with acetone crumble in someone's hand. Your best bet is probably goo gone or isopropyl alcohol.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
