Go to Post I’m not decently dressed for this picture.......I have no FIRST shirt, FIRST hat or FIRST pin anywhere on me! - Rich Wong [more]
Unread 15-01-2016, 18:55
RoboKnight RoboKnight is offline
FRC #5496
RoboKnight is an unknown quantity at this point
RoboRIO Imaging Tool Error Message
I have recently re-imaged the roboRIO to the 2016 image. However, afterwards I was greeted with this message, despite the fact that the roboRIO states both on this and the IP address that it now has the correct configuration.
We are having some issues with our roboRIO and now, whenever we attempt to reconfig and reapply we are given this message. I was wondering if there is any risk of only a partial download that would state we have the correct version despite it not being fully complete. I would also like to know how to get rid of this error as to reconfigure and reapply in the future if necessary.
Unread 15-01-2016, 19:22
Jonathan L. Jonathan L. is offline
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Re: RoboRIO Imaging Tool Error Message
I can't see the image. Could you re-post it as an attachment?
Unread 16-01-2016, 13:46
FRC #5496
https://docs.google.com/drawings/d/1...it?usp=sharing
Here is the image again
Unread 16-01-2016, 14:49
bohdand bohdand is offline
FRC #1099
bohdand is an unknown quantity at this point
We just tried imaging our new roboRIO and have the exact same error message. We did successfully download the latest firmware first.
We also tried to do the image in safemode and it still failed. We rebooted the PC and roboRIO with the same error.
We were able to imaged last years 2015 roboRIO using the same computer with the new 2016 image and it worked.
Anyone have any other idea?
Unread 16-01-2016, 15:41
FRC #1099
Update: We think we figured out the problem. Using the USB cable and loading the roboRIO web server at 172.22.11. 2 (same way as you update the firmware) we enabled the Console out and the Secure Shell, rebooted the roboRIO and we were ten able to download the firmware.
Let us know if that worked for you.
Unread 17-01-2016, 00:15
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
3937 was experiencing the same error message, but when I took a roborio home, I was able to update it just fine. Through a process of elimination, we concluded it was while our nav6 was connected to the roborio that it was having issues. Mentioned this to one of our older mentors, and he remembered that we had to disable the console out (which proved to resolve the issue).
If you have a nav6 (or anything else plugged into the rs-232 port), you need to disconnect it while to image the roborio and unselect the 'enable console out' checkbox on the imaging tool.
Unfortunately, if you are not using the serial port, than your error is likely unrelated.
Unread 17-01-2016, 09:21
FRC #1099
When we had our problem, we did not have anything connected to the roboRIO except power and the USB cable.
Unread 21-01-2016, 22:03
mhamzaqayyum mhamzaqayyum is offline
FRC #6008
mhamzaqayyum is an unknown quantity at this point
Hi, can someone please tell me how to get the latest 2016 v19 firmware for the roborio? We've been struggling for the past few days trying to update the firmware to the latest one, since we keep getting incompatibility errors in eclipse.
Thanks
Unread 21-01-2016, 22:39
Penchant Penchant is offline
FRC #4607
Rookie Year: 2015
Penchant has a spectacular aura aboutPenchant has a spectacular aura about
Thanks
If you are simply interested in how you acquire the latest firmware, its through installing the 2016 FRC Update Suite. Of course the next question is, "Where does it get installed?"
I happened to be using Screensteps for updating the firmware and noticed in the image the file path, which is Program Files (x86)\National Instruments\Shared\Firmware\cRio\76F2\
Unread 27-01-2016, 01:57
FRC #6008
Got it, thanks!
