Go to Post We considered naming our 2014 robot "Please Don't Point it at Me". I think the name fits. - KosmicKhaos [more]
Unread 25-01-2016, 16:06
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
RoboRio Ethernet Connection Through Hub
We are planning to use multiple ethernet-connected devices on our robot this year, but since the new Wireless Bridge only includes 2 ports, we purchased an ethernet hub to expand the number of ports we can use.
We are currently using one of the Bridge's ports to connect to the roboRio, and the other to interface with the hub (which we can plug our other devices or tether into).
However, in our current design we want to mount the Bridge in an area that will maximize reception/connection strength, while the roboRio and switch are sitting next to eachother in another area of the robot. Rather than running two ethernet cables from that area to the Bridge, we proposed running the roboRio to the hub, then hub to Bridge with a single cable. That way, the second port on the Switch is very accessible for tethering at competition, and we make the wiring extremely efficient.
However, I noticed the rule:
R58 The Wireless Bridge must be connected to the roboRIO Ethernet port (either directly or via a CAT5
Ethernet pigtail).
Does this exclude our proposed setup? Technically our bridge is still connected to the roboRio, albeit through a hub, via CAT5 ethernet.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 25-01-2016, 16:12
Re: RoboRio Ethernet Connection Through Hub
No, that layout wouldn't get past inspection (although you can try an appeal to the Q&A), and it really isn't a good idea to add more devices to such a mission critical path anyway.
Only connect the roboRIO and radio directly together, no intermediate network devices, and use the radio port closest to the radio power connector (just a strong suggestion).
Unread 25-01-2016, 16:18
seg9585's Avatar
AKA: Eric
Hmm, okay, we may look for a way to relocate the hub close to the desired Bridge location instead (rather than close to the roboRio)
My FIRST legacy:
Unread 26-01-2016, 14:57
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
What is the reasoning behind this suggestion?
Unread 27-01-2016, 07:31
Eric,
I am going agree with Mark here. Your first priority is being able to drive the robot. Everything else is secondary and useless if the robot is not driving.
One thing that many teams ignore is the minimum bend radius on the cables they are using. When you violate this simple concept, the conductors inside the cable begin to migrate and degrade cable performance. Conductors tend to pull out of connectors as well. On cheap cables I have seen wire shorts when the cable is bent at less than rated minimums.
Unread 27-01-2016, 07:53
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
When you zip tie the two cables together for support, they start out more or less next to each other. If you use the other port, it's farther away and you end up with a sharper bend to your first zip tie.
FIRST is trying to eliminate points of failure in the primary systems. A length of working CAT5 cable is unlikely to stop working in a match. Two lengths and a powered switch have more possible fail points.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 29-01-2016, 11:26
Robonut
AKA: Mr. Lam
Rookie Year: 2015
Ah! Yes, that makes sense.
I was trying to think of electrical reasons why to favour one port over the other
Edit: see post below - didn't realize there were differences in the ports on the OpenMesh radio.
Unread 29-01-2016, 11:35
Tying the cables together securely is one reason.
The two ports on the OpenMesh are also setup differently, for instance the Open Mesh should be configured through the 802 port while the POE port handles power input.
From Beta testing and other Beta reports the POE port seemed to be less prone to roboRIO connection issues like the one's in some of the current CD threads.
In general, I recommend following FIRST's instructions, since they might add adaptations to the firmware, get all the bug reports, do their own confirmation testing, as well as have the manufacturers ear.
But if you encounter repetitive issues with one port, try the other.
Approximately one percent (made up statistic) of the radios might suffer from manufacturing oddities that benefit from wiring that one percent differently than what may be the standard FRC practice.
