Go to Post Ya know...sometimes, design specs get changed at the last second. Or the market changes while you weren't watching. It Happens. - DonRotolo [more]
Unread 26-01-2016, 09:14
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Rhino Track Shooter
Due to the unavailability of the rhino tracks and their high cost, we could never build a prototype of a rhino track shooter. Just wondering if there were any teams out there who tried that setup that would be willing to share their experiences. Seems like you could build up a lot of speed with them.
Good enough is the enemy of anything great!
team 1671
Unread 26-01-2016, 09:17
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Re: Rhino Track Shooter
I'm sure there's a team out there who has tried it, but sharing Prototypes is a foreign concept for some teams.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 26-01-2016, 09:34
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
I believe you could build a belt shooter for a much lower cost than a rhino drive module costs. Those are designed to carry a 140 pound machine over field obstacles. All this would have to do is throw a light foam ball.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 26-01-2016, 21:28
FRC #5817 (Uni-Rex)
Don't doubt that you could, just was wondering if anyone out there had given it a try with that track.
team 1671
Unread 26-01-2016, 22:04
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
I am confused as to the concept of a "track shooter" is this like a spinning wheel shooter but with tank treads?
could someone please explain
Unread 26-01-2016, 23:59
FRC #5817 (Uni-Rex)
Something kind of like this: http://delta-engineering.be/wp-conte...3/CSG_BASE.png
Giving it a lot of speed building up.
team 1671
Unread 27-01-2016, 00:18
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Back in 2006 our shooter used a section of rubber covered wire mesh (commonly used in pool chairs) wrapped into a belt as a combination feed belt and the bottom half of a shooter (we had a second fly wheel on top of it for the other half of the shooter). Worked pretty good, though it was hard to keep it in its track.
Unread 27-01-2016, 08:16
CJ_Elliott's Avatar
CJ_Elliott CJ_Elliott is online now
FRC #2502 (Talon Robotics)
CJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of light
Team 1711 did something similar in 2014.
Here ya go
Unread 27-01-2016, 09:11
FRC #5817 (Uni-Rex)
Not quite what I was looking for but that is okay. You would need a different holder with a conveyor or pneumatic pusher into the belts so that they could get up to speed. Allowing a more powerful shot than in the video.
team 1671
Unread 28-01-2016, 10:52
evoluti1's Avatar
evoluti1 evoluti1 is offline
AKA: Joe
FRC #1197 (TorBots)
evoluti1 has a spectacular aura aboutevoluti1 has a spectacular aura about
If you're not bearing the load of an entire robot, you could try just using off-the-shelf conveyor belting, that is without the synchronous belt backing that Rhino Tracks have. We tried some last year on an intake prototype and it wasn't *too* hard to implement (though definitely would be more work than a wheeled shooter for any team). It would be a challenge to keep everything running smoothly at high speeds, but then again the Rhino treads might have the same issues.
Unread 28-01-2016, 11:23
pwnageNick's Avatar
pwnageNick pwnageNick is online now
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
We also had a similar shooter to this concept in 2012, just not with the rhino track/belt material:
http://www.chiefdelphi.com/forums/sh...d.php?t=104961
It does help get to a higher exit velocity and keeps that more consistent without relying on ball density.
Note: in the above video we were running double belts. by the end of the season we had switched to having two rigid poles on the top instead offl the belt, so it kind of became a shrouded shooter but with a belt.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
