Go to Post Like a wizard, Car Nack is never late. He always arrives precisely when he meets you. - EricH [more]
Unread 26-01-2016, 10:48
RoboAlum RoboAlum is offline
Mickey D's
FRC #4841 (Optimal Robotics)
RoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the rough
pic: First Custom Chassis
Unread 26-01-2016, 10:49
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Re: pic: First Custom Chassis
...there's cross members, right?
Bellypans provide support but not all types of support.
Unread 26-01-2016, 10:57
Mickey D's
yes we have a top cross bar just not shown in picture
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 26-01-2016, 10:58
Thaddeus Hughes
Just a top bar? It's hard to provide moment reactions with just a bar linked in at one point per side.
Unread 26-01-2016, 11:07
Mickey D's
what would you recommend?
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 26-01-2016, 11:29
Thaddeus Hughes
Top is what I'm interpreting that you have planned, bottom is what I would suggest. Something that links in at multiple points so that the combination of force reactions produces a moment.
https://goo.gl/photos/wxTJnghMbhq163Md7
Something like
Last edited by ThaddeusMaximus : 26-01-2016 at 11:30. Reason: google images is weird
Unread 26-01-2016, 11:31
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Out of curiosity... how are you attaching bumpers to the front/back corners? You'll need some sort of frame member extending past the wheel on the corner, but your outside plates appear to stop short.
If it were me, I would add support with some more C or square tubing across the front and back. Bolt it into the existing C channel and into the belly pan.
As an example, here's our custom chassis this year (We've only done a custom chassis once before, in 2009).
2016: Lake Superior WFFA
Unread 26-01-2016, 11:51
Mickey D's
were building an upper structure that will pertrude outward past the tires while still being under 15"
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 26-01-2016, 13:28
philso philso is offline
FRC #2587
Originally Posted by Jon Stratis View Post
Is that the base for a turret?
Is that a mechanism for determining the width of your chassis?
Unread 26-01-2016, 20:22
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
We had a similar design a few years back in 2012 and we ended up having turning issues. We had gearboxes on our corner wheels then chain running from the rear wheels to the center wheels all 6 wheels were powered but this still caused some turning issues. At the time we also had the same exact tires on our robot. What will happen when turning with a drop center design is the weight is going to transfer to the middle wheels (powered) and the front corner wheels (unpowered). When this happens only 50% of your powered wheels will be touching the ground and it can cause some turning issues. A simple fix for this would be to add another belt run from the center wheels to the front wheels, your team could do this in a multitude of ways. Let me know if you have any more questions, good luck!
Unread 26-01-2016, 23:39
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Looks nice!
I'm curious about the plywood bases for the bumpers in the corners -- it almost looks like they may be screwed right in to the frame (unless those are captive fasteners I see and the bolt comes in from the robot side and is removable) and would be hard to remove from the robot after the fabric is added.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 27-01-2016, 00:00
Originally Posted by Ken Streeter View Post
Looks nice!
The plywood for the bumpers is bolted into the 1x1 uprights, which then fit into slotted members that are welded onto the frame. We'll be drilling straight through the bracket and the 1x1 uprights to add some pins to hold it together. In the picture above, the bumpers literally can be pulled straight up and off the robot.
But, it is nice to have the bumpers proceeding apace with the rest of the robot! Fabric should be screen printed and ready for sewing sometime next week, and by then we should have the attachment process finished.
With manipulators that hang outside the frame perimeter and needing to get down to the ground, having bumpers in place early is an absolute must!
Unread 27-01-2016, 08:23
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I spy a tape measure.
461 Westside Boiler Invasion
45 Technokats
Unread 27-01-2016, 09:20
FRC #2587
It is very nice to see a robot where the bumpers are not an afterthought.
Unread 27-01-2016, 09:25
How else do you measure your bumper length?
