Go to Post More inspired students, more community involvement, less drain on the mentors... Sounds pretty swell to me! - Karthik [more]
Unread 26-01-2016, 17:35
Slade Slade is offline
FRC #4471 (Spartrons)
Slade is an unknown quantity at this point
PDP Lights are flashing Orange
So we had our PDP plugged into the RoboRio at first and the Stat and Comm lights were flashing green.
But recently we hooked up a PCM along with a compressor and 2 double solenoids.
Everything was fine and was working, but all of a sudden the PDP started flashing orange and the compressor wont turn on even when the robot is enabled. When I go onto the web client of the RoboRIO it shows the PCM and when I self test it, it says the following:
PCM IS NOT ENABLED! If robot is enabled maybe the ID is wrong?
Close-Looping is ON, but PCM is DISABLED.
Comp Is Off
Pressure is not full
I have tried rapidly clicking self test but thats not working.
Thanks in advance!
Unread 26-01-2016, 17:41
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: PDP Lights are flashing Orange
Did you check the blade fuses?
More info on the PDP
http://content.vexrobotics.com/vexpr...e-20150305.pdf
Specifically the 20a VRC, PCM fuse.
In addition the manual linked above has your failure state as : Robot is disable / Sticky Fault Present.
Was any code changed recently?
Check here on the various LED errors, scroll down to PDP.
http://wpilib.screenstepslive.com/s/...uick-reference
Also, did you do any firmware updates? Were all electronics updated?
Good luck,
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 26-01-2016, 17:55
Good luck,
Aloha
The blade fuses were checked and fine
We did make a change earlier but we reverted them. Also I had tried to put a blank robot code on and we're still getting the same error.
Unread 26-01-2016, 18:06
TikiTech's Avatar
Mr. H
I did check those manuals I linked for you.
I would take the system to its simplest configuration.
In this case, setup the RoboRio and PDP. Disconnect everything else.
If the error still exists then reimage, update all the firmware, drop in some generic code.
After that, you might have to get FRC involved. Is this a new PDP with old PCM or visa versa? All new or old?
There are many variables and you need to simplify as much as possible to ease in troubleshooting.
If all else fails, the PDP could be failing, as one of the manuals mentions that this error condition can indicate a hardware failure.
Perhaps there is a team close that is willing to try your PDP or lend you one of theirs.
Good luck with this. If you are still stuck keep on posting.
Aloha!
Unread 26-01-2016, 18:20
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
The PDP and PCM do not affect each other like that. In other words the PDP does not prevent the PCM to enable compressor output through software (although the PDP does power PCM, the PCM is clearly running since it self-tested).
Please follow the instructions in section 4.1 in PCM User's Manual to get the compressor working.
http://www.ctr-electronics.com/contr...ical_resources.
Unread 26-01-2016, 18:56
So we took it to its simplest form and I had updated the PDP firmware earlier and re-imaged the RoboRio. Nothing worked. Its still flashing orange. Were not sure what it is. It flashed red at first but after a few seconds of it being on the lights turn orange.
Also, the PCM seems to be fine. It's a solid green when the robot is activated, yet the compressor still isnt running.
Unread 26-01-2016, 19:02
TikiTech's Avatar
Mr. H
I would start from the beginning like mentioned. Setup just the PDP and RoboRio. Nothing else. Redo all firmware and robot code in case of corruption.
If you cannot get these two devices to work together properly then there is probably a hardware issue with the PDP.
Adding the PCM is pointless if you cannot get just the PDP and RoboRio working together correctly.
Unread 26-01-2016, 19:22
We went home, but we'll try this tomorrow. Thanks!
Unread 26-01-2016, 23:12
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Guys, if your PDP is flashing orange that means sticky fault/ robot disabled. The most common cause is a low battery.
Go to the Rio config page, click on the PDP, double click self test rapidly. You should now have green flashing lights. Note that the red lights at startup are due to no can communication while the Rio boots.
Because of the momentum and direction of this thread I highly recommend anyone who posted here go read the PDP users guide tonight. Even just viewing the pictures would haved pointed you in this direction. You may find you are missing other critical tips.
I win! XD
Unread 27-01-2016, 08:55
We had tried double clicking the self test as said in the first post. Thanks though!
Unread 27-01-2016, 09:03
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
You have double checked the CAN id right? If the CAN id does not match the id you initialize with in your code, you will see this exact same behavior.
Unread 27-01-2016, 11:04
I believe so. I mean I don't even recall ever initializing a CAN. All I did was set the solenoids to go to the default PCM(0). Also, when it did flash green, I don't recall ever enabling a CAN manually.
Unread 27-01-2016, 11:29
Schnabel's Avatar
AKA: Eric Schnabel
FRC #0469
Originally Posted by Slade View Post
<snipped>When I go onto the web client of the RoboRIO it shows the PCM and when I self test it, it says the following: <snipped> I have tried rapidly clicking self test but thats not working. <snipped>
emphasis mine
Please verify you did so for the PDP though, your first post reads as you did so on the PCM, not the PDP.
I win! XD
Unread 27-01-2016, 13:05
emphasis mine
I'm not 100% sure, but I'll try in an hour or two and let you know.
Unread 27-01-2016, 15:19
So we did the self test on the pdp and it's still orange.
