Go to Post Representing data in a good way is an art in its own right. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 26-01-2016, 21:51
climavarus's Avatar
climavarus climavarus is offline
I do stuff with robots sometimes
AKA: Steinley
FRC #4593 (Rapid Acceleration)
climavarus is an unknown quantity at this point
New to Python: wpilib doesn't exist.
When trying to deploy my code to the robot, I get the error saying:
"ImportError: No module named 'wpilib'".
Our programming team this year is new to python, and we have no idea as to how to make this work. Running last years' code works fine, despite also having the library imported. Any ideas as to why this is happening?
Unread 26-01-2016, 22:18
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: New to Python: wpilib doesn't exist.
Where is the error happening? Any other output that you might see could be helpful here.
How are you trying to deploy code to the robot?
Do you have pyfrc installed on the computer that you're trying to deploy to the robot? What version (you should be using a 2016 version)? If you're on Windows, you can find out by doing this on the command line to see what packages you have installed:
py -3 -m pip list
Or on linux/OSX:
pip3 list
Unread 27-01-2016, 09:40
climavarus's Avatar
AKA: Steinley
Man, you just made me realize what the issue is, I overlooked it in my frustration. We completely forgot to install pyfrc, and we hadn't done it yet because we've been having issues with pip as well. I don't remember what errors we were getting, but I'll give that another go.
But to answer your questions:
It's happening at the top of the code, and stops when it can't import wpilib. That's about all the output we're getting, just a couple lines of error message.
We're deploying code through the code's directory with
py robot.py deploy
So, we should be able to get this fixed now. Hopefully, my personal computer will be more forgiving than the teams programming computer so that I can figure this out.
Unread 27-01-2016, 09:47
virtuald's Avatar
RobotPy Guy
If you don't use python for things other than robotpy, I would recommend just uninstalling your old version of python (and ensuring that C:\Python34 is deleted) and installing Python 3.5. It comes with pip, and should work out of the box.
Unread 27-01-2016, 13:56
climavarus's Avatar
AKA: Steinley
That should solve our problem entirely, thanks for the help!
