Go to Post You heard it here first folks. The robot will definitely need wheels and will probably have an arm. - DampRobot [more]
View Poll Results: What launching method are you using for FIRST Stronghold?
Single-sided wheeled launcher 66 28.09%
Double-sided wheeled launcher 84 35.74%
Linear accelerator (pneumatic powered) 5 2.13%
Linear accelerator (elastic spring/surgical tubing) 12 5.11%
Rotating arm (catapult, trebuchet, etc.) 35 14.89%
Another method (please share in comments!) 7 2.98%
Launching? No thanks. 26 11.06%
Voters: 235. You may not vote on this poll
Unread 27-01-2016, 08:38
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Poll: What type of launcher mechanism are you using for FS?
Curious about the launching mechanism your team has decided on and why you may have chosen that method.
Thanks, everyone!
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 27-01-2016, 08:58
Fields's Avatar
Fields Fields is offline
Classic
FRC #5637 (Titanium Polars)
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
Re: Poll: What type of launcher mechanism are you using for FS?
We're trying the elastic tube (not so much for ease, but it's fun trying to build a slingshot for a 10 inch boulder)
Problem is right now it launches like 10 feet! Anyone else getting better results?
Unread 27-01-2016, 09:06
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Ours went about 50 feet... https://www.youtube.com/watch?v=QT2OmzrAhPI
Would recommend more strands of surgical tubing, do not stretch them beyond 200%, and replace them between events for consistency.
Unread 27-01-2016, 09:19
MechEng83's Avatar
AKA: Mr. Cool
We decided to go for a compression spring linear accelerator, similar to a pin-ball machine.
Our concern with the surgical tubing to power the system was the degradation over time and variability due to ambient conditions. That being said, it does provide the ability to quickly change the power by adding or removing tubes to the system. With the rules about only launching from the courtyard, high-powered launching for full-court shooting wasn't necessary.
We had considered going with the wheeled shooter (either single or double sided). This seemed like the best way to have variable launch speeds but decided against that due to our experience with the 2012 game piece and its manufacturing variation in both surface texture and compressability. I'm seeing more threads that suggest this may be an issue this year too.
Red Alert Robotics
Unread 27-01-2016, 10:52
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
1747 is using a double-sided, sequential wheeled shooter. The goal is to make the trajectory of the ball between the robot and the upper tower opening as close to linear as possible by maximizing ball velocity. With any luck we should get a test shot off with our competition shooter tonight.
I really hesitate to speculate what it will do, but the theoretical maximum ball velocity is about 88 mph and the shooter is ~1.8 horsepower worth of motor. Everyone on the team can't help but grin or giggle when we talk about it, because it is absolutely silly and the very definition of overkill.
It's going to be something...
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 27-01-2016, 10:58
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
There is no such thing as overkill Team 1708 is going with a sort of two wheel shooting approach but not on both sides. Hope to have a picture up tonight.
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Fields's Avatar
Classic
Rookie Year: 2015
I'd like to see what happens. Good luck!
Unread 27-01-2016, 10:59
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Have fun trying to launch such a large ball through such a small goal. Launching? No thanks.
Unread 27-01-2016, 11:59
MechEng83's Avatar
AKA: Mr. Cool
Results at 100 responses:
Single-sided wheeled launcher				25	25.00%
Double-sided wheeled launcher				35	35.00%
Linear accelerator (pneumatic powered)			2	2.00%
Linear accelerator (elastic spring/surgical tubing)	4	4.00%
Rotating arm (catapult, trebuchet, etc.)		18	18.00%
Another method (please share in comments!)		4	4.00%
Launching? No thanks.					12	12.00%
Looks like we're going to see a lot of wheeled launchers at the competitions this year.
Red Alert Robotics
Unread 27-01-2016, 12:22
Knufire Knufire is offline
What if we have more than one boulder scoring mechanism?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 27-01-2016, 12:23
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
The catapult/trebuchet design fits the theme better, so clearly it's the best solution. If a team works out how to make a trebuchet launcher with a resetting sling I will be thoroughly impressed! It will be interesting to see how many catapult style launchers are pneumatic vs mechanical spring vs latex powered.
That's what I thought for the first few days after kickoff. After we had a field mocked up and tested some prototypes, I changed my mind. It's a tough target, but it's doable.
Unread 27-01-2016, 12:56
MechEng83's Avatar
AKA: Mr. Cool
Is more than one of them a launcher? If we need to score low, we plan on just reversing our intake, so we technically have multiple scoring mechanisms.
Red Alert Robotics
Unread 27-01-2016, 13:09
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is offline
John Rangel
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
I think he may be referring to a modular shooter robot that can be a short robot that scores in the high goal or a tall robot that shoots in the high goal based on alliance partner's robots. It was one of our ideas at one point early on in the season but ultimately gave it up.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 27-01-2016, 14:05
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Our prototype pneumatic catapult. We made 3/4 of our first shots. Quit while we were ahead and went to production.
http://youtu.be/XQA1Bx_qfUM
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 27-01-2016, 14:14
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
Video is private.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
