Go to Post There are times when we talk as friends and joke around about things like this, but then the most important times are when he says "I'm telling you this as a mentor," no matter what it is, those moments mean a lot. - Akash Rastogi [more]
Unread 27-01-2016, 14:39
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
Arrow Re: Drive train PID control
More or less yes. So you're using talons. PWM I assume? if so, the following code should be enough to set up your drive.
using only basic classes:
Talon leftDrive=new Talon(1);
Talon rightDrive=new Talon(2);
//if using gamepad
Joystick gamepad=new Joystick(1);
//if using two individual joysticks
Joystick leftJoy=new Joystick(1);
Joystick leftJoy=new Joystick(2);
Encoder leftEncoder=new Encoder(1,2);
Encoder rightEncoder=new Encoder(1,2);
PIDController leftPID=new PIDController(0.1,0,0, leftEncoder, leftDrive);
PIDController rightPID=new PIDController(0.1,0,0, rightEncoder, rightDrive);
public void robotInit()
leftEncoder.setPIDSourceType(PIDSourceType.kDisplacement); rightEncoder.setPIDSourceType(PIDSourceType.kDisplacement); rightEncoder.setReverseDirection(true); rightDrive.setInverted(true); //only one side needs inversion leftEncoder.reset(); rightEncoder.reset(); leftPID.setOutputRange(-0.75,0.75); //max speed it can set to motors rightPID.setOutputRange(-0.75,0.75); //max speed it can set to motors leftPID.enable(); rightPID.enable();
} public void autonomousPeriodic() {
leftPID.setSetpoint(400); rightPID.setSetpoint(400); //set distance. you can change distance per tick through the encoder
} public void teleopInit() {
leftPID.disable(); rightPID.disable();
} public void teleopPeriodic() {
//for two joysticks leftDrive.set(leftJoy.getY()); rightDrive.set(rightJoy.getY()); //for one gamepad leftDrive.set(gamepad.getRawAxis(1)); rightDrive.set(gamepad.getRawAxis(2)); //replace 1 and 2 axis with actual axis number.
"you can build a perfect machine out of imperfect parts" -Urza
