Go to Post All those crazy teenagers walking around Atlanta trying to "Save the world" looking like gang members with their attire. - BrendanB [more]
Unread 26-01-2016, 15:49
moomoomoo309 moomoomoo309 is offline
FRC #0224
moomoomoo309 is an unknown quantity at this point
Data from GRIP not available in Java Code
I've been using a roboRIO and trying to get a Contour Report from GRIP into my code. GRIP works well enough; data comes from it and into the Network Table viewer (I can see all of the data in the Network Table Viewer!). Once I attempt to get the data from the NetworkTable into my code, it does not work.
What I've tried (in teleopPeriodic) given table=NetworkTable.getTable("GRIP/myCountoursReport")):
  • Printing out table.getKeys() (which is empty)
  • Checking if a given index (I.E area) exists (table.containsKey("area") was false)
  • Publishing a different number into the GRIP table and trying to get that (put the framerate into the table, NetworkTable.getTable("GRIP").getNumber("myNumber" ,Double.NaN) returns NaN)
Do you have any advice for how I can fix this problem, or any other diagnostic steps you may need?
Unread 27-01-2016, 12:43
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: Data from GRIP not available in Java Code
Is OutlineViewer in client mode or server mode?
What is the NetworkTables server address in GRIP?
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 27-01-2016, 14:35
FRC #0224
The OutlineViewer is in client mode and the NetworkTables server address is roborio-224-frc.local. GRIP deploys fine, and the data is correct in the OutlineViewer, but I can't import any NetworkTables.
Unread 27-01-2016, 14:37
FRC #0237
What is GRIP running on?
Can you share a screenshot of your pipeline?
Unread 27-01-2016, 14:48
FRC #0224
GRIP is running on a Windows 7 laptop, and here's the pipeline.
Unread 27-01-2016, 14:59
FRC #0237
Everything seems OK from the GRIP side of things. Can you post a link to your full robot code?
Unread 27-01-2016, 15:07
FRC #0224
http://pastebin.com/8WrBNeK6
Here's the code. When I get the table, it always returns an empty one.
Unread 27-01-2016, 15:17
FRC #0237
PHP Code:
table NetworkTable.getTable("GRIP/myCountoursReport");
should be
PHP Code:
table NetworkTable.getTable("GRIP/myContoursReport");
Unread 27-01-2016, 15:26
FRC #0224
Thank you, that fixed it. It's always the simple mistakes that get us.
On a side note, why did "NetworkTable.getTable("GRIP").getKeys()" return an empty set? Shouldn't it have "myContoursReport" in it?
Unread 27-01-2016, 15:28
FRC #0237
getKeys() returns the set of values directly inside the GRIP table. I don't think it include subtables.
getSubTables() is probably what you're looking for.
