Go to Post F.I.R.S.T. Troubleshooting Rule #1 - If you work on software, the problem is always with hardware. If you work with hardware, the problem is always with software ;) - Redneck [more]
Unread 01-18-2016, 02:56 PM
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
Rev Robotics MXP Digit board Java code
Here is or team's Java code for getting the Rev Robotics Digit board to display text. The code is in the team 1493 GitHub:
https://github.com/FIRSTteam1493/Rev...rd/tree/master
The character repository contains the byte binary codes for each character (note that each character takes up two elements in the array). Characters are printed from right to left on the 14-segment displays (so the first character in byte1 will end up in the rightmost display). You store whatever you want to print in byte1, then run i2c.writeBulk(byte1) to write it to the board's internal RAM and therefore to the displays. Right now the code is set to cycle through all 36 characters, but you can change that to whatever you want.
Cheers!
-1493
Unread 01-19-2016, 03:58 PM
floogulinc's Avatar
floogulinc floogulinc is offline
AKA: Paul Friederichsen
FRC #2879 (Orange Thunder)
floogulinc is an unknown quantity at this point
Re: Rev Robotics MXP Digit board Java code
Please rename the code file to have the .java extension so there is syntax highlighting.
Unread 01-25-2016, 04:13 PM
Crossle86's Avatar
Crossle86 Crossle86 is offline
Software Engineer
AKA: Richard Corn
FRC #4450 (Olympia Robotics Federation)
Crossle86 is an unknown quantity at this point
We are trying out your code but have not had success displaying characters. A question: where did you locate the i2c port number value? I have looked all over and not found that documented. I'm curious how you found it.
Unread 01-26-2016, 09:51 PM
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MR. T)
The Doctor is on a distinguished road
I'm working on a library to simplify this... I'll test it tomorrow and put it up ASAP.
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 01-27-2016, 11:07 AM
Crossle86's Avatar
Software Engineer
AKA: Richard Corn
Actually we did get this code to work. Again, my question is how did you determine the i2c port number to use?
Also, whatever function we use to read the pot on the analoginput, we get large values, in the range of 208-224. I was expecting (as documented) to 0 to 5, at least using getvoltage function. Have not used analoginput before so seems I am missing something...
Unread 01-27-2016, 04:33 PM
The Doctor's Avatar
Robotics is life
AKA: Hackson
FRC #3216 (MR. T)
The I2C port number is constant, hex 0x70. The analog input, last i checked, is a value from 0 to 1024 that maps to a value of 0-5v.
Unread 01-27-2016, 07:28 PM
RamTech 59 RamTech 59 is offline
RamTech 59
FRC #0059 (RamTech 59)
RamTech 59 is an unknown quantity at this point
The GitHub address isn't going anywhere. It is saying servers are busy or something. Do you have a direct download link for this?
Unread 01-27-2016, 09:17 PM
The Doctor's Avatar
Robotics is life
AKA: Hackson
FRC #3216 (MR. T)
Github is down right now, be patient. I don't have the code they posted, but in the mean time, you could try out the library I wrote (soon to Github`d)...
Edit: github seems to be up, see this thread:
http://www.chiefdelphi.com/forums/sh...42#post1531242
Just in case, here's a backup: http://pastebin.com/NKBatYgZ
Unread 01-27-2016, 10:01 PM
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
It's listed on page 25-26 of the HT16K33 datasheet. The address is selectable by connecting the A0/A1/A2 to the AD pin via a resistor through a diode.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 01-28-2016, 12:05 PM
Crossle86's Avatar
Software Engineer
AKA: Richard Corn
Yes, I understand the port number is hex 70. My question is how you determined the value is 70. Did you find this in some documentation, or code or online? I have not been able to find this information and I want to know how one comes by this port number value.
