Go to Post Wait, does this mean TV isn't real? I'm shocked and appalled. - s_forbes [more]
Unread 22-01-2016, 17:13
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Extremely Broken Code Please Help!
I have no idea why the issue with this program escapes me. I have been looking at it for days with no headway. Maybe a new set of eyes can see the problem. The program is simple. It uses my XBox class to control a four motor arcade drive system using one of the joysticks on the controller. Some buttons then control a couple accessory motors.
Here is the code: https://github.com/FranklinMarquette/Robot2016
Here is what the driver station says when I try to enable the robot:
ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]ERROR Unhandled exception: java.lang.ExceptionInInitializerError at [org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 3), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]
The whole thing compiles and uploads just fine but fails at run-time.
Thanks so much,
Franklin
Unread 22-01-2016, 17:36
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Extremely Broken Code Please Help!
So I notice code breaks here and the motor1Stop class has
public static Motor1 motor = new Motor1();
while the motor1Move class does not. Try removing this?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 23-01-2016, 13:34
kgross kgross is offline
kgross is an unknown quantity at this point
Not sure what is causing your error yet, but it sounds like an undefined pointer.
But you should move a few lines around in your Motor1 and Motor2 classes. Right now you have the instantiation of the SpeedController above your constructor.
SpeedController motor = new Victor(4);
public Motor1() {
change it to.
Private SpeedController motor;
public Motor1(){
Unread 25-01-2016, 16:46
LFRobotics's Avatar
FRC #4623
Okay so I applied those changes and have updated the code here:
And it returns this error:
ERROR Unhandled exception: java.lang.IllegalArgumentException: Subsystem must not be null. at [edu.wpi.first.wpilibj.command.Command.requires(Com mand.java:194), org.usfirst.frc.team4623.robot.commands.Extend.<in it>(Extend.java:16), org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 6), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:44), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]
Thanks for the help
Unread 25-01-2016, 19:23
ArchdukeTim
Just a quick question. Are you reading the errors or just posting them here? It's ok if you are because they aren't the most lovely things to read (though you should try. It'll be much faster) What it's giving you is what's called a stack trace. It basically tells you the path the code took before it got an error. I've added a comment on what the error tells you.
edu.wpi.first.wpilibj.command.Command.requires(Com mand.java:194),  #6
org.usfirst.frc.team4623.robot.commands.Extend.<in it>(Extend.java:16), #5
^------------This is the file-------------------------^---------------Line #- ^
org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 6), #4
org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:44), #3
du.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), #2
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)] #1
So you start at the bottom and read up. Notice how it goes to robotInit at #3, then goes into OI at 4, then to the Extend class. At Line 16 (note my comment in the code) is where the error is. Looking at line 16 in the code shows
requires(Robot.pnue);
Looking in the Robot class I can see pneu, but the problem is it's initialized AFTER OI. So OI is looking for a null object, hence the error. Try putting OI after everything.
Unread 25-01-2016, 20:29
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
twiggzee is an unknown quantity at this point
I'm having the same problem. Compiles just fine but red light on driver station robot code.
When I comment out everything in public OI{}, I get green light on driver station robot code. But why??
TimTheGreat: What do you mean by "Try putting OI after everything"?
Thanks for your reply!
Wendy
Team 3502
Unread 25-01-2016, 20:39
ArchdukeTim
So in LFRobotics' code he has
        oi = new OI();
        pnue = new Pnuematics();
The problem is when you create a new OI object, it looks for robot.pneu. But as you can see pneu hasn't been created because it is after new OI(). So put new OI below the creation of everything else (in this case swap them).
Unread 25-01-2016, 22:50
LFRobotics's Avatar
FRC #4623
Okay that makes perfect sense. I did trace it back and could deduct that it had something to do with the extend class but never thought of movie the onus constructor
Thanks
Unread 26-01-2016, 17:43
Yes! That worked! Thanks so much, TimTheGreat!!!
Wendy
Team 3502
Unread 26-01-2016, 22:39
ArchdukeTim
Glad I could help
Unread 27-01-2016, 17:08
LFRobotics's Avatar
FRC #4623
Okay so moving that fixed it. Now the pnuematics are not working.
What does this error mean?
ERROR Unhandled exception: edu.wpi.first.wpilibj.util.AllocationException: Solenoid channel 1 on module 0 is already allocated at [edu.wpi.first.wpilibj.DoubleSolenoid.initSolenoid( DoubleSolenoid.java:54), edu.wpi.first.wpilibj.DoubleSolenoid.<init>(Double Solenoid.java:81), org.usfirst.frc.team4623.robot.commands.Retract.<i nit>(Retract.java:12), org.usfirst.frc.team4623.robot.OI.<init>(OI.java:5 7), org.usfirst.frc.team4623.robot.Robot.robotInit(Rob ot.java:42), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]
I have tried moving stuff around and changing simple things but it keeps throwing the same error.
Thanks again,
Franklin
Unread 27-01-2016, 17:21
ArchdukeTim
Is your code up to date in the github repo?
PS: A good way of reaching me is on the Freenode IRC channel #robotpy. If you're on then you can have quick discussion which is a lot faster than CD
Unread 27-01-2016, 21:45
LFRobotics's Avatar
FRC #4623
That's not what I changed it to today but that code threw the same error - the ports for the double solenoid are 0 and 1
Unread 27-01-2016, 22:05
ArchdukeTim
Ok I think the problem is when you call the retract command you create a new solenoid on ports 0 and 1. Don't do this. If you call the retract command more than once (or call the extend command once) then you can't call it again because it tries to create a new solenoid. Create the solenoid somewhere and pass it to the command.
