Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
Unread 27-01-2016, 13:01
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Labview Project, how to start?
Please confirm for all of us that you are following the instruction on this link!!! Installing the FRC 2016 Update Suite (All Languages)
With or without the encryption code. "The password was removed at some point yesterday."
Tell us you are seeing the screens shown in this document
There is an Addendum - Installing on Windows 8 at the bottom of this web page if that is the problem.
Tell us what you see different than what is shown in Installing the FRC 2016 Update Suite (All Languages) so that we might be able to tell what has gone wrong.
Omar
Unread 27-01-2016, 17:09
AmAlienRobot's Avatar
AmAlienRobot AmAlienRobot is offline
RaiderNation
FRC #3815 (Raider Robotics)
Team Role: Operator
AmAlienRobot can only hope to improve
Well it was doing fine, I built it and when I wet to deploy this, this happened..
Unread 27-01-2016, 17:41
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
It looks like you've got the Update Suite installed and were able to get a project put together.
The project is going to try to talk to your roboRIO assuming you've run this year's image on it. You can do that by choosing roboRIO Imaging Tool 2016 from the Utilities tab on the splash screen.
The name for the roboRIO is slightly different than it was last year. Open up IE and look for roboRIO-TEAM-FRC.local where TEAM is your team number. You should be able to see a web utility for your roboRIO here. If not, we're likely running into issues with the IP address.
Are you connecting via USB or Ethernet currently?
