Go to Post It's important to know that it isn't always best to have biggest machine out there. - Quatitos [more]
Unread 27-01-2016, 17:41
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
Re: Labview Project, how to start?
It looks like you've got the Update Suite installed and were able to get a project put together.
The project is going to try to talk to your roboRIO assuming you've run this year's image on it. You can do that by choosing roboRIO Imaging Tool 2016 from the Utilities tab on the splash screen.
The name for the roboRIO is slightly different than it was last year. Open up IE and look for roboRIO-TEAM-FRC.local where TEAM is your team number. You should be able to see a web utility for your roboRIO here. If not, we're likely running into issues with the IP address.
Are you connecting via USB or Ethernet currently?
