Go to Post Frisbees [as next year's game piece]. That is all. - Frenchie461 [more]
Unread 27-01-2016, 17:43
Sparta3648's Avatar
Sparta3648 Sparta3648 is offline
Mentor of team 3648
FRC #3648 (Sparta Robotica)
Sparta3648 is an unknown quantity at this point
Is modification to a COTS part allowed?
With AndyMark Pneumatic tires not an option our team has opted for using HarborFreight 10 inch pneumatic tires. In order to make them compatible with our drive-train/axle system we are 3D printing compatible hubs. Are tires of this kind and modified in this manner allowed?
Unread 27-01-2016, 17:47
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Is modification to a COTS part allowed?
Modification to COTS parts is allowed. Just keep in mind that post-modification, it is no longer a COTS part but a FABRICATED ITEM
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 27-01-2016, 17:56
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
In general, modification to COTS parts are allowed. The exceptions (for safety reasons) relate to motors, motor controllers, and pneumatics. There is probably a rule regarding the roborio and related parts.
Unread 27-01-2016, 18:43
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Details:
R30 The integral mechanical and electrical system of any motor must not be modified. Motors, servos, and electric solenoids used on the ROBOT shall not be modified in any way, except as follows:
R66 The Driver Station software, roboRIO, Power Distribution Panel, Pneumatics Control Modules, Voltage Regulator Modules, RSL, 120A breaker, motor controllers, relay modules, Wireless Bridge, and batteries shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, rewiring, disassembling, etc.), with the following exceptions:
R76 All pneumatic COMPONENTS must be used in their original, unaltered condition. Exceptions are as follows:
Please note that each of those rules does contain a small list of exceptions (not copied here).
2016: Lake Superior WFFA
Unread 27-01-2016, 19:51
DonRotolo's Avatar
Back to humble
FRC #0832
Screwing a plastic hub to a COTS item doesn't make the COTS item non-COTS, does it? Kinda like using a clamp to hold a broomstick, the broomstick is still COTS.
Of course, the OP seems to be replacing the hubs with plastic bits; this makes it non-COTS (unless the tire is available separately, which remains COTS then)
Unread 27-01-2016, 20:05
Well...
The COTS item is still a COTS item. However, the whole thing is now a Fabricated Item (by means of assembly) and thus no longer COTS (unless it was sold as a COTS assembly, for example a wheel and hub sold as one unit). However, if you took the two items apart, they would be COTS again.
Unread 27-01-2016, 20:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If your 3-d printed hubs do not require you to modify the COTS wheels, they're still COTS. As they are not actuators or control systems, you are pretty much at liberty to modify them as needed. However, if you drill or cut on them, that makes them fabricated items rather than COTS. The only difference between COTS and FABRICATED items is that fabricated parts must be made after the start of build season (a few exceptions, bumpers, and attachments), and are not exempt from bagging/withholding rules (an even smaller set of exceptions).
Unread 28-01-2016, 15:48
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Tires = COTS
3D printed hubs = fabricated item
Put together, you have a fabricated item (assembly).
Unread 28-01-2016, 19:59
Tires = COTS
Gear box = COTS
Motors = COTS
Control System = COTS
Chassis = COTS
Put them all together, and you have a fabricated item.
