Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 26-01-2016, 19:38
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Stress testing a Rhino
Originally Posted by AngryCalculator View Post
Our team has ordered the treads, and I've been a little worried about just the four crossmembers. Although it looked fine in the video, I think a bellypan and/or diagonals would really help.
I'm not convinced a belly pan would help. In fact, it may hurt.
Look at the 11 second mark, that frame looks to flex, which may help in keeping the frame from being damaged.
___________________
- Tennyson, Ulysses
Unread 27-01-2016, 08:42
philso philso is offline
FRC #2587
This is the thinking behind the energy absorbing structures in modern cars that allow them to protect occupants better than older cars with "a massive frame" where the forces from the impact are transmitted through the frame to the passenger compartment.
Unread 27-01-2016, 09:17
Racer26 Racer26 is offline
I can't speak to the Rhino units in particular, but the belts on them look awfully similar to some belts made by Brecoflex that my old team used for several years. They were expensive (read: $150+/belt) and had a tendency to break under heavy side-loading. With all the up and down shock loading of the drivetrain in 2016 traversing DEFENSES, I would be extremely skeptical of any belted drives.
Unread 27-01-2016, 13:06
Malm Malm is offline
FRC #2526 (Crimson Robotics)
Malm is an unknown quantity at this point
Thank you all for the information!
I am now also very interested in the T-bone test, hopefully we can do it soon if nobody else is able to post results earlier.
Regarding the belts breaking - I am also very concerned about that. We have 2 spares (from our practice chassis), hopefully that will get us through our first regional if they start breaking.
Unread 27-01-2016, 13:49
Andy A. Andy A. is offline
Getting old
FRC #0095
Reminds me of one of the coolest pair of videos on youtube (to me, anyways)
Dropping a F-18 Hornet at maximum landing weight from 20 feet up.
In slow moation
Bonus of the F-35C undergoing the same sort of test
Unread 27-01-2016, 15:48
Originally Posted by sportzkrazzy View Post
I think Mike is searching for its ability to spin off of a robot playing defense on it not the structural integrity. If a track drive is hit close to its center of rotation it may have issues spinning off a robot playing defense on it creating a death spin type scenario where you cannot drive forwards or backwards out of the Tbone. This results in both robots making circles locking your robot up instead of enabling it to score. A lot of wheeled Tank style robots have had this issue as well. One way to mitigate this is to use low coefficient of friction bumper materials. This decreases the amount of friction between the two surfaces that your robot is trying to slide off of. You could also think of a way to change your center of rotation by dropping an omni wheel. Remember its not a pin unless your robot is up against a field surface so in theory they could do it the whole match.
Quick question to the group:
The middle of the 3 wheels contacting the ground on the Rhino has an 0.15" dropped center. We were planning on keeping our center of gravity roughly over this axle, so when accelerating forward it should drive on the portion of the tread between the the back two wheels and when accelerating backwards it should drive on the tread between the front two wheels, shifting the center of rotation by about 9". Obviously we still need to do the actual T-bone test, but does anyone think that this shift in center of rotation would be significant enough to solve the problem of being permanently locked to another robot?
Unread 27-01-2016, 16:09
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
Director
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Breakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really nice
One of the things you have to remember is how you support the track that is on the ground or the will be impacted during play. If you have a wheel over the backing of every bit of track that touches the ground, the belt has very little room for traverse movement or elongation. Especially since the Rhino Tread has a v groove backing. However, as you remove idler pulleys or wheels from that area, you belt has a lot of room for extension past its length. It can only handle 600 pounds of force, as I have read on the AndyMark website, so the more it extends or deforms, the more force that builds on the tread. Just make sure that if you are using the tread, you make great considerations for hitting the defenses wide open with a 140 pound robot on a section of tread that is not supported. This is probably the number way to break these treads in this years game.
"There is no luck. It is only when preparation meets opportunity."
Unread 27-01-2016, 18:32
Bob Steele's Avatar
AKA: Bob Steele
I saw the title of this thread and was expecting something different
I was wondering where you would get a big enough tread mill.....
Unread 27-01-2016, 19:33
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Photoshop challenge.
March, or die!
Richard Wallace
since 2003
Unread 27-01-2016, 21:32
Bob Steele's Avatar
AKA: Bob Steele
here you go
Name:	rhino on treadmill.jpg
Unread 27-01-2016, 21:37
Bob Steele's Avatar
AKA: Bob Steele
I guess this would work....zoos actually use these to exercise elephants... Rhino=Elephant?
Unread 27-01-2016, 23:55
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Think about it like this. If a robot Can hit both centers of rotation with the span of its front bumpers will you be able to spin off of it? How hard will it be for a defensive driver to line up on you? You can still experience these issues with a drop center wheeled drive as well. Just some food for thought.
Unread 28-01-2016, 09:47
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
The sides of the Rhinos are 3/16" aluminum plate with supports every few inches and are incredibly solid, so we are not too worried about T-boning. (That said, we are planning on having full length bumpers and external frame rails to help protect them as well.)
Will the huge amount of grip make T-bones harder to get out of? Plenty of teams have relied on lateral slipping to get out of T-bones in the past (find 118's 2013 reveal video, there's a little clip of drop-down omnis) and the insane traction from the Rhinos may have the exact opposite effect. I'm also curious if a hard lateral impact will shove the tracks off the pulleys temporarily. Unfortunately, we can't test these things in-house, but I really would like to see more of the Rhino Drive so we can get a feel of how they will perform in competition. From what I've seen so far, they are really good with the B/D defenses, but it still begs the question- why aren't tank treads popular, except for games with terrain? If they came with repercussions as significant as their benefits, I could see why they aren't very common. Yet, so far, the Rhino drive has shown pretty much no significant disadvantage versus a traditional tank drive.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 28-01-2016, 09:56
That makes sense. In this case, do we expect the tank treads to perform any worse than drop-center wheels with the same spacing?
Edit: Didn't see evanperryg's response, that answers my question
Thank you all!
Unread 28-01-2016, 10:12
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I think the reason we don't see more tank tread drivetrains is the lack of performance advantage compared to well-designed conventional wheeled drivetrains, while at the same time introducing substantial disadvantages (cost, unreliability, even reduced performance).
Mentor 2415
