Go to Post Don't let the teams here be so much of an intimidation to you, but instead, an inspiration. They all had to start from the beginning, too. - Amanda Morrison [more]
Unread 26-01-2016, 14:34
VrewDaive VrewDaive is offline
FRC #4284
VrewDaive is an unknown quantity at this point
Xbox Controller with mecanum drive
Hello, I'm a first year FRC programmer and was curious on how to use the Xbox 360 controller as both joysticks for the
myDrive.mecanumDrive_Polar(moveStick.getY(),moveStick.getX() , rotateStick.getTwist());
I don't know how to designate the certain sticks of the controller to either moveStick or Rotate stick and also am confused on how to assign them in the declaration
myDrive =  new RobotDrive(0,1,2,3);
    	moveStick = new Joystick(1);
    	rotateStick = new Joystick(2);
Any help appreciated; Ive already looked over the other chief delphi post over this subject but am still lost. Thanks!!
Unread 26-01-2016, 18:45
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Xbox Controller with mecanum drive
getY() and getX() are intended for flightstick not xbox controllers
i think the code you want is
robotDrive.mecanumDrive_Cartesian(joystick.getRawAxis(whateverYourXAxisIs), joystick.getRawAxis(whateverYourYAxisIs), joystick.getRawAxis(whateverYourRotateAxisIs), whateverYourGyroValueIs)
Unread 26-01-2016, 22:45
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
The buttons on the controller follow this mapping
1: A
2: B
3: X
4: Y
5: Left Bumper
6: Right Bumper
7: Back
8: Start
9: Left Joystick
10: Right Joystick
The axis on the controller follow this mapping
(all output is between -1 and 1)
1: Left Stick X Axis
-Left:Negative ; Right: Positive
2: Left Stick Y Axis
-Up: Negative ; Down: Positive
3: Triggers
-Left: Positive ; Right: Negative
4: Right Stick X Axis
-Left: Negative ; Right: Positive
5: Right Stick Y Axis
6: Directional Pad (Not recommended, buggy)
taken from http://www.chiefdelphi.com/forums/sh...45&postcount=8
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 27-01-2016, 14:02
FRC #4284
so would something like this work as expected?
     */  RobotDrive myDrive;
    	Joystick moveStick;
    	Gyro gyro;
    public void robotInit() {
    	Talon TalLF = new Talon(0);
    	Talon TalLR = new Talon(1);
    	Talon TalRF = new Talon(2);
    	Talon TalRR = new Talon(3);
    	myDrive =  new RobotDrive(TalLF,TalLR,TalRF,TalRR);
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
     * This function is called periodically during operator control
    public void teleopPeriodic() {
    	//while(!isAutonomous() && isEnabled())
    		//myDrive.mecanumDrive_Polar(moveStick.getRawAxis(1),moveStick.getRawAxis(2) , moveStick.getRawAxis(4));
    		myDrive.mecanumDrive_Cartesian(moveStick.getRawAxis(1), moveStick.getRawAxis(2), moveStick.getRawAxis(5), gyro.getAngle());
    		Timer.delay(0.01);
Unread 27-01-2016, 19:00
ArchdukeTim
Yeah that should work.
Also, are you meaning to do field-oriented drive (pushing up on the left joystick makes the robot move away from you, no matter which way it's pointing)?
Unread 28-01-2016, 09:46
CjDace CjDace is offline
FRC #4284
CjDace is an unknown quantity at this point
honestly at this point no. I just want the drive to work correctly, Do we have the gyro assigned correctly?
  RobotDrive myDrive, catcherDrive;
	    	Joystick moveStick;
	    	Gyro gyro;
myDrive.mecanumDrive_Cartesian(moveStick.getRawAxis(1), moveStick.getRawAxis(1), moveStick.getRawAxis(1), gyro.getAngle());
Unread 28-01-2016, 09:48
FRC #4284
that was me.... on a different account
Unread 28-01-2016, 17:09
ArchdukeTim
	    	Joystick moveStick;
	    	Gyro gyro;
Well you don't create it, at least in the code you show here. If you don't want field-oriented get rid of the gyro.getAngle() in the mecanumDrive constructor and replace with 0.
