Go to Post Analyze, adjust, anticipate. Don't panic. - PayneTrain [more]
Unread 27-01-2016, 19:51
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Is modification to a COTS part allowed?
Screwing a plastic hub to a COTS item doesn't make the COTS item non-COTS, does it? Kinda like using a clamp to hold a broomstick, the broomstick is still COTS.
Of course, the OP seems to be replacing the hubs with plastic bits; this makes it non-COTS (unless the tire is available separately, which remains COTS then)
Unread 27-01-2016, 20:05
Well...
The COTS item is still a COTS item. However, the whole thing is now a Fabricated Item (by means of assembly) and thus no longer COTS (unless it was sold as a COTS assembly, for example a wheel and hub sold as one unit). However, if you took the two items apart, they would be COTS again.
Unread 27-01-2016, 20:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If your 3-d printed hubs do not require you to modify the COTS wheels, they're still COTS. As they are not actuators or control systems, you are pretty much at liberty to modify them as needed. However, if you drill or cut on them, that makes them fabricated items rather than COTS. The only difference between COTS and FABRICATED items is that fabricated parts must be made after the start of build season (a few exceptions, bumpers, and attachments), and are not exempt from bagging/withholding rules (an even smaller set of exceptions).
Unread 28-01-2016, 15:48
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Tires = COTS
3D printed hubs = fabricated item
Put together, you have a fabricated item (assembly).
Unread 28-01-2016, 19:59
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Tires = COTS
Gear box = COTS
Motors = COTS
Control System = COTS
Chassis = COTS
Put them all together, and you have a fabricated item.
