Go to Post I'm 5'5", and I'm our team's drive coach. Our drivers are nearly always taller than me. In my case, it's not the driver's station that needs to be made of lexan...it's our drivers. - StephLee [more]
Unread 27-01-2016, 19:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
AM14U3 Kit Chassis Mods to traverse DEFENSES
We spend some time trying to figure out how to go over the DEFENSES, and finally came up with this. It seems to work so far, although we just got it running, and the chassis is not anywhere near it's final configuration, and there's not ball handling stuff on it. We intend to make a short robot, the electronics will be on the side near the front, the ball will go down the center of the robot (in one end, out the other).
The lower four wheels are mounted on aluminum brackets, we were very careful to keep the center to center distance for the belts just right, so it took a few days to perform the modifications.
What ideas have you come up with to deal with this?
https://www.youtube.com/watch?v=yWUq1fw4mCE
Unread 27-01-2016, 19:57
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: AM14U3 Kit Chassis Mods to traverse DEFENSES
That is a very cool solution, we played around with a staggered 10 wheel drive in a configuration like that but able to go both directions easily. When belts turned out hard to track down we went back to what seems to be the favorite of pnematic wheels.
What's your plan for bumbers on the front? What will make up your rigid mouth out front?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 27-01-2016, 20:10
MrForbes's Avatar
AKA: Jim
Right now we're working on just a few pieces of wood screwed into the ends of the frame, then the original C channel across the wood to tie it together. One neat thing about this design is that it puts the chassis up into the bumper zone.
Unread 27-01-2016, 20:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We're planning a 10 wheel robot this year. 8 8" and 2 4" wheels in a 2015 KoP chassis. Yes, I know that the diameters on one side add up to 36" and the robot is only 32" long (before the wedge that we were going to add even before AM made it an easy COTS thing). Our wheels lie in 4 planes rather than two, and we currently have different treads for the inboard pair of 8" wheels than for the corner wheels. We haven't tested it yet in the real world (vice CAD), but we're on track to do so this Saturday. After this post, I'm rather sanguine that we'll be able to cross the rock wall, moat, rough terrain, and ramparts as easily as the low bar.
Our ball pickup is going to double as lifter and lowerer to get through the portcullus and cheval de frise. Our basic designs just needed some minor tweaks to make this (virtually) work.
Finally, we're leaving the drawbridge and sally port as too easy to defeat via cooperation between two or three robots with working drive trains to waste a mechanism upon.
Unread 27-01-2016, 20:31
MrForbes's Avatar
AKA: Jim
Interesting...one of the ideas we had was to have two kit chassis modules next to eachother with wheels overlapping! But it turns out to be kind of difficult to implement, and it doesn't seem to be necessary.
We're also planning on having a mostly passive ball intake, we really don't want to have to make any extra mechanisms. Too much KISS on our team, I suppose, and I'm probably to blame.
Unread 27-01-2016, 20:36
RichQuinn's Avatar
RichQuinn RichQuinn is offline
FRC #5053 (Lakers)
RichQuinn is an unknown quantity at this point
That's a terrific solution for the KOP chassis. Great job with lateral thinking.
Those crossings look downright graceful compared to many, and if your drivers can be trained to keep an easy pace, it should pay off in long term machine durability.
Regarding the lack of bumpers up front and excessive rear overhang: It's funny to look at the pre-drilled chassis and wish you could just shift the entire pattern one way or the other. Would make life a little easier.
Great progress. Good luck with the rest of the build.
Unread 28-01-2016, 01:57
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Great solution!
Unread 28-01-2016, 06:35
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Very nice!
I noticed you minimized the open spaces between the wheels. That seems to be the key to going over the moat.
We tried a skid plate with our 6" wheels and had some minor success.
Just got 8" pneumatic wheels in today, so will be some time before we can try them out on the real bot.
Can you post video going over the ramparts?
Dave
Unread 28-01-2016, 09:17
MrForbes's Avatar
AKA: Jim
We haven't made the ramparts yet, that's something we need to get done this week.
Unread 28-01-2016, 09:24
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
This is great! We actually came up with a similar solution with our 8" Pneumatic 8WD. Front wheel is raised about 2 inches, making the pass over the rock wall and rough terrain easy. We also crammed the 8 wheel profile into as short of a length as possible, to ensure continuous wheel contact with the defenses.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 28-01-2016, 13:16
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
have you put any weight on that chassis and retested?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 28-01-2016, 13:21
MrForbes's Avatar
AKA: Jim
We have the 20 lb weights on the front of it, and the electronics enclosure on the rear...and I don't expect our robot to be much heavier. (oh yeah...another 15 lbs of bumpers!) But this video was taken yesterday about an hour before I left, so no, we haven't had a chance to play with weight on it yet.
Unread 28-01-2016, 17:48
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Interesting...one of the ideas we had was to have two kit chassis modules next to each other with wheels overlapping! But it turns out to be kind of difficult to implement, and it doesn't seem to be necessary.
We don't actually have two modules, but we have increased the width of each side module by 1 1/2" and switched from belts to #25 chain to make room for two ranks of wheels. We gear down 2:1 from the drive axle to the dead axles, which makes the 4" wheel on the drive axle go the same speed as the 8's. We're designing a tortoise to face off against the hares. We just have to do some testing to make sure we're not a tortuga.
Unread 28-01-2016, 17:56
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Have you tested over metal, which may not give you as much traction as wood?
Unread 28-01-2016, 20:50
MrForbes's Avatar
AKA: Jim
That's on the agenda for the next day or two. We're making the chassis be the final size right now, then we can do more testing.
