Go to Post Redfoo is actually a really awesome guy. He discussed the future of engineering and talked about C programming with our software team. - SM987 [more]
Unread 26-01-2016, 23:35
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Encoder on SRX Returning wildly differing values
Just hooked up our E4P encoders, and we are getting wildly differing values. I confirmed that my java code matched the the rio browser selftest output. All firmware is up to date. I am pretty sure it is not a coding problem.
If you push the joystick forward for 2 seconds 1 encoder will read several thousand revolutions the will read a couple hundred. The wheels are spinning just fine. The robot move in perfectly straight line.
How do you confirm that an encoder is damaged or wired incorrectly?
Unread 26-01-2016, 23:54
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: Encoder on SRX Returning wildly differing values
Do you have the encoder counts per revolution configured correctly? This was an issue for us for a little while.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 27-01-2016, 00:13
FRC #3944
We've done no configuring yet. Just out of the box, working with get methods just to get a feel for them. The browser and my code match. I think the one is damaged. They are off by thousands. We are dependent on our electrical team to swap, and I was wondering if there is a way to prove it is physically damaged without just swapping it out.
Unread 27-01-2016, 09:55
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
You can be 100% sure of you code not being the issue if you use the web interface to the RIO and do a self-test on each Talon SRX. There you will see raw encoder counts measured by the SRX.
Unread 27-01-2016, 11:55
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
I would start by swapping the wires from the encoders to the SRXs to see if the speed follows the encoder or the SRX.
If the encoder, reseat the optical disk using the spacing tool that came with the encoder. A long shot, but check the lines per rev on the optical disks, there are several options available from 100 per rev to 360 per rev. You can try to count them or the count should be engraved on the inner hub of the disk.
If it follows the SRX it is most likely an error in the code or that one SRX had it's defaults changed (perhaps last year) and the other did not.
Unread 27-01-2016, 21:30
FRC #3944
Thank you, I did do that and that is how I was sure it was not a Java error.
Unread 27-01-2016, 21:33
FRC #3944
The long shot was most likely the problem. Electric engineer was available tonight to come over and break it down. Turns out that the optical disk on one side is 250 and 360 on the other. The person doing the work to mount them must not have seen it.
Unread 27-01-2016, 21:35
FRC #3944
Thank you all for replying. I suspected it was a config problem but I thought it would be a good topic to have on the boards for others to learn from
Unread 27-01-2016, 22:19
Just curious: how do you guys store and label E4P encoders and their disks when you are not using them on a bot?
Unread 28-01-2016, 01:19
FRC #3944
Let's put it this way, The mechanical team will not be handling delicate equipment any more.
We will put a system in place to properly store and catelogue electronics. If u have any suggestions please share them. Love to hear it.
Unread 28-01-2016, 08:36
The E4P optical disks are fragile and easily damaged. They must be handled and stored with great care. When they are damaged (scratched or smudged) or improperly installed they can cause frustrating problems that may be difficult to diagnose.
Store optical disks individually in clean lint-free labeled soft plastic bag, inside a small labeled box. Store that small box inside a larger labeled box containing the rest of the encoder parts.
Team policy: no one handles or installs until they have been properly trained.
Unread 28-01-2016, 21:20
FRC #3944
Amen! Thanks and grateful for your input. Our competition encoders E4Ts and mag encoders and boards from our great CTR vendor are in transit right now. and they will be kept in the china cabinet until our electronics mentor is ready for them. We might be getting a new fridge this summer I am thinking about turning the old fridge into a robot part storage cabinet.
What was great about the problem was the kids got to see how to diagnose the issue and confirm it was broken. We took the optical reader off and cleaned it with an alcohol wipe. Did some manual turns of the wheels. It was a good night.
The other thing that came out of the effort was some of the tasks our pit crew will be doing to check the bot after we compete. Learned a lot from the mistake.
Unread 30-01-2016, 00:04
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Another useful sanity check is oscilloscope-ing the A/B outputs of the optical encoder while it's spinning. Just in case this helps anyone, here's a video demonstrating this...
http://www.ctr-electronics.com/downl...odEncoders.mp4
