Go to Post Don't be too distracted by the shiny robots, and the games they play. Enjoy them, but keep your eyes on the real prize(s). - gblake [more]
Unread 27-01-2016, 21:13
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Tapping into 3D Printed Parts
Thinking about making a custom, 3D-printed part. However, it would require making a thread (6-32 or 8-32, I can't remember off the top of my head).
Anyways, would this be a feasible task? I know that delrin can be threaded into, and like the filament used in 3D printers, delrin is made of plastic. If this is something that can be done, what filament was used, and with what print settings?
Thanks
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 27-01-2016, 21:23
pilleya's Avatar
pilleya pilleya is online now
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Tapping into 3D Printed Parts
Delrin is an entirely different material to PLA or ABS and is much easier to machine and is supremely stronger, and would definitely be capable of holding a thread. Delrin is known as an "engineering plastic" for these reasons.
I think it is important to make the distinction between an "engineering plastic" and a material like PLA or ABS.
In regards to tapping a thread into 3D printed material, I don't think that the type of plastic is the issue, it is more method of printing. A printer that uses PLA or ABS prints in layers, meaning that these layers are points of weakness, the thread would have to go through these layers and would be reliant on these for strength. If a part is 3d printed with the hole that is going to be tapped already on the model, there will be concentric circle infill around this and this is the major point of weakness. Ideally the thread and print head nozzle diameter, would have to be selected to ensure that the edge of the thread was not a the point where two of the concentric circles join.
I think it could be feasible, but it would most likely be unsuitable for a high stress/load component.
What you could do is design the component in such as way, that you can use a nut embedded in the print to hold the thread. Make a nut shaped/sized hidden void in the middle of the print. Just before the printer, starts to make the lid of the void, pause the print and place a nut into void. It will then print over the nut and enclose it inside the print
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Unless you are looking to use a very course thread, don't tap into the 3D printed part directly. Instead, use threaded inserts such as Helicoils:
http://www.mcmaster.com/#helicoils
I've used Helicoils before in FDM 3D printed parts with good success.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-01-2016, 21:26
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Depends on your printer, some may even be able to print the threads for you.
If you plan on drilling and tapping, you have to make sure the hole placement will have enough "stuff" for you to tap the threads into. As most 3D printers, use some form of internal honeycombing technique on the parts to conserve filament.
If the part is designed right what you ask is possible, however you must consider if the materiel your 3D printer uses is strong enough for the task.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 27-01-2016, 21:32
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
I don't know how good of an idea this is for a 3d printed plastic part but: Make a hole in the 3d printed part from one side that is the size of the outside of a nut that matches the size you need (in the CAD file of the part itself), or just make a circular hole the size of the diameter of the nut. After this is done secure it in place using epoxy or other methods (3d print over it lol). This would mimic tapping it, although I have absolutely no Idea how well it would work (might be worth trying). I now this is completely anecdotal evidence but, I did this on a wood part for a non-FRC related project and it seemed to hold up pretty good. Good luck!
Unread 27-01-2016, 21:34
AKA: Daniel Koh
Team Role: CAD
Oh wait, I didn't mean 3d printing the thread. I meant making the 3d printed part, then using a tap/die set to make the threads.
Of course, the layers are going to be an issue with this, but if this is possible, then I got access to at least 3 or 4 3d printers with the part I'm thinking about
-KohKoh
Unread 27-01-2016, 21:39
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Thanks
What are you planning on doing with said part if you don't mind me asking?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 27-01-2016, 21:43
AKA: Daniel Koh
Team Role: CAD
My team has a tradition for keeping things secret, but I will say that this is going to be interacting with a piston from FESTO, which has around 55-58 lbs of force. At this point, it's dependent on how strong the part is going to be.
-KohKoh
Unread 27-01-2016, 21:44
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Last year we used brass threaded inserts that we installed using a soldering iron to heat the insert and press into place in the 3D printed part. Worked well for us...
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
Unread 27-01-2016, 21:46
What kind of printer are you using?
Unread 27-01-2016, 21:49
pilleya's Avatar
Elec+Mech
Although rather impractical, 3D printing can work for printing threads as long as they are reasonably large. I obviously wouldn't suggest using them for anything that requires strength, but for securing motor controllers etc, 3D printed nuts and bolts could make a lightweight replacement for steel (Or just use zipties and double sided tape!)
I built my own 3D printer a few years ago, so I often print quite pointless things, such as nuts and bolts.
http://imgur.com/rCDYqYE
Nate Laverdure's Avatar
FRC #2363
On our 2015 robot, the big yellow gear is an FDMed ABS plastic part with a tapped hole used for a set screw. Here's another. These parts were modeled with holes sized for 75% thread, printed with 2-3 shell layers and 20-30% infill, and carefully tapped. Worked fine for this extremely low-load application.
This resource is great for understanding the distinction between types and grades of plastics. Hangs in my office.
Unread 27-01-2016, 21:53
pilleya's Avatar
Elec+Mech
If used as a rod end, I don't really think a 3D printed part will work, because all the force, is trying to pull the thread out the the 3D printed part, the chance of success is dependent on how long the thread is.
Unread 27-01-2016, 21:54
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Could you run a hex hole in the opposite side of your part and then place a nut in that hole? We used this for a camera mount where the nut was press fit into a hole and it allowed the bolt to thread through from the other side.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 27-01-2016, 22:05
sdangelo sdangelo is offline
FTC #10842 (Train of Thought)
sdangelo has a spectacular aura aboutsdangelo has a spectacular aura about
My team did this with PLA for a part that supports the entire weight of our FTC robot (~12 lbs) over four screws that are roughly that size. It's been working just fine for us, but we don't have nearly as much force on it as you intend to. It was printed on a Makerbot Replicator 2x and I think we used the standard settings for temperature and layer height, but we increased the infill to maybe 20 or 30% and the number of shells to 3. I think the infill won't really matter for tapping something; the number of shells is going to determine the thickness of the plastic around the holes that you want to tap.
Here's a picture of the part with the screws in it. Our mountain-climbing mechanism goes on the top and the bottom attaches to our robot's bellypan.
https://drive.google.com/file/d/0Bzk...ew?usp=sharing
