Go to Post I think applying Gracious Professionalism to strictly legal game play trivializes what is a much more important and fundamental FIRST concept. - jimfortytwo [more]
Unread 27-01-2016, 23:56
Eloy1073 Eloy1073 is offline
FRC #5261
Eloy1073 is an unknown quantity at this point
Problems driving straight.
Hello team 5261 here. We drive rotate fine and can get by going forward and backwards but whenever we try to go faster like down a hall it seems the robot starts to turn left. I think this happens because one motor is faster than all the other. If someone could please tell me what the problem is or how to slow down just one specific motor.
USING LANGUAGE JAVA
Unread 28-01-2016, 00:03
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Problems driving straight.
If you try moving the wheels by hand, does one side seem more difficult to move than another? Does one side of the drive sound differently to another? If you have more than one motor per side, make sure all motors are actually running (try one motor plugged in at a time and see if you notice anything). Without sensors to read it could be difficult to tell, though sound is usually a decent indicator
Check that all your motor controllers are properly calibrated. Check that you are using the same motor controllers on all motors in the drivetrain.
If you are using chains/belts, check tension, perhaps one is tighter than the other and causing issues. Did you lubricate gears? Is anything potentially bent in a weird way? Is your drivetrain square (that is are both sides parallel)?
Chances are the problem is a mechanical or electrical one. It is not impossible but most likely not a software problem, unless you are trying something fancy coding-wise.
Unread 28-01-2016, 00:17
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
USING LANGUAGE JAVA
What are you using for a controller?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 28-01-2016, 00:25
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
It could be mechanical as others have indicated (chain being tighter one one side, one sides gearbox not being assembled as smoothly as the other, etc), but it could also be electrical - if one of the motor calibrations are way off for some reason, that could be an indicator. Read up in the user guides of the motor controller for how to calibrate.
Also are you using arcade drive (pushing forward on one joystick makes both sides go forward?) Otherwise it might be user input making it veer off a little bit.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 28-01-2016, 00:37
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Not only could one motor be running slower, but one motor could actually be running REVERSE relative to the others. We've done this before, so check your program that each rotates the same direction as the others. You may need to do some dis-assembly to make sure each motor is running the right way.
Unread 28-01-2016, 01:32
philso philso is offline
FRC #2587
Welcome to Chief Delphi
There is already a thread where someone is having a similar problem. You may find some useful information there.
http://www.chiefdelphi.com/forums/sh...hreadid=142645
Unread 28-01-2016, 05:33
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Is the hallway floor slick? try it on carpeting.....
Unread 28-01-2016, 06:02
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
If you are using dead axles (round bearings supported by bolts) make sure the bolts are a little loose. Like others have said, take the system apart and test each component separately and then as it is reassembled.
Is your robot's CoG centered side to side? If one side of your bot is heaver it may increase friction and cause you to turn in that direction.
As others have said, if your frame is not square, your robot won't track straight. If the bearings on one of your motors or wheels has higher friction, you bot won't go straight.
If its not mechanical, you could try using a 'Y' cable so each motor controller gets the same PWM signal.
You can program a button to pass both sides of the robot the same value or use a 'Y' cable to distribute the same PWM signal to the right and left sides of the bot. If the bot goes straight with this set up its likely your joystick controller is the issue.
The key to finding the problem, is to be able to rule out each component in a systematic fashion. Let us know what you try and the results.
Dave
Unread 28-01-2016, 08:26
This should be shouted from the rooftops.
Unread 28-01-2016, 08:47
FRC #5261
Not near the bot at the moment but will try all those when I get the chnace later today.
Unread 28-01-2016, 08:48
FRC #5261
An Xbox afterglow controller.
Unread 28-01-2016, 08:50
FRC #5261
We're using tank drive for mecanum. This isn't for the 2016 bot because we a haven't completed. But all the programmers this year are new to programming so we wanted something to test on.
Unread 28-01-2016, 12:37
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Two different gearboxes will never produce the same exact output power/torque/rpm, because small variances in gear friction and efficiency can drastically change the performance.
I assume you don't have encoders you can use to match the wheel speeds?
If not, then simply add a "bias" multiplier to the motors in the faster gearbox so its max speed is slower such that it matches the other gearbox.
For example, if the robot is steering to the left, that means the right gearbox needs to be slowed down:
bias=0.9; // Figure out what number to use here until the robot drives straight, should be between 0 and 1 noninclusive
leftmotor.set(joystick.getY());
rightmotor.set(joystick.getY()*bias);
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 28-01-2016, 12:54
ryanjacobs's Avatar
ryanjacobs ryanjacobs is offline
AKA: Ryan Jacobs
FRC #1708 (Amp'd Robotics)
ryanjacobs is an unknown quantity at this point
Sometimes motors don't run at the same exact rate. You can either play around with new motors, program one motor to be slower than the other or, my personal favorite, use a gyroscope! Gyros are easy to program, very useful, fun to use! Good luck with everything
Unread 28-01-2016, 13:53
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Since you mentioned mecanum ... ensure that all the rollers take the same force to spin. A really tight or loose roller will cause your robot to veer off
___________________
- Tennyson, Ulysses
