Go to Post FIRST is like pizza. You and I may like different toppings, but in the end it's still delicious pizza. - Billfred [more]
Unread 28-01-2016, 02:22
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Re: Fitting a Magnetic Encoder on Ball Shifter
First we tried printing the bottom half of the shell, but adding legs to make it a single mount and sensor holding setup. Turns out re-making something that someone already made is a waste of time, so we wound up designing a simple little printed "bracket" to mount the mag encoder for our solution.
Here's an early print of the mag encoder bracket. If you'd like, I can send you the CAD for it. (that print was NASTY. Z-offset wasn't dialed in, the bed wasn't quite leveled right, and the temp settings weren't dialed in yet)
If you have 3D printing ability, it makes mounting these a breeze.
Edit: Here's the .stl for the mount. The central holes are sized appropriately based off the SRX Mag Encoder housing, and the center hole is large enough to allow spacing of the magnetic plug. Using barely oversized plastic also allows you to align the sensor to the magnetic. Turns out slop can be useful!
