Go to Post Robotics is fun, but it isn't the most important thing in life. - Wayne TenBrink [more]
Unread 27-01-2016, 22:53
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Tapping into 3D Printed Parts
Originally Posted by MrBasse View Post
Could you run a hex hole in the opposite side of your part and then place a nut in that hole? We used this for a camera mount where the nut was press fit into a hole and it allowed the bolt to thread through from the other side.
THIS. Probably my favorite way to fake threads in a 3D printed part.
Helicoils (as Arthur mentioned above) are also good. I prefer to use the standard threaded inserts from McMaster usually though: http://www.mcmaster.com/#standard-th...serts/=10vencg
They do not require the special helicoil insert tool.
Unread 27-01-2016, 23:07
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
A T nut seems like it was invented for this. Just print the hole the diameter of the T Nut and you're golden
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 28-01-2016, 06:37
lovelj's Avatar
lovelj lovelj is offline
FRC #3824 (RoHawktics)
lovelj is an unknown quantity at this point
Originally Posted by mwmac View Post
Last year we used brass threaded inserts that we installed using a soldering iron to heat the insert and press into place in the 3D printed part. Worked well for us...
Yes, this is by far the most effective means of including threads on printed parts.
Mentor: FIRST Team 3824
Oak Ridge National Laboratory
Manufacturing Demonstration Facility (MDF)
http://web.ornl.gov/sci/manufacturing/
Unread 28-01-2016, 23:18
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
IMO, the best way (without a helicoil or nut insert) to have an axial loaded internally threaded screw hole in 3D printed parts is to just have an undersized pilot hole and use a coarse thread deep V-groove (not machine thread ) screw that can cut its own thread on 1st installation. Some plastic compatible lube my help avoid tearing up the material as screw forms the thread.
This should also allow for best results when multiple cycles of assembly and disassembly will be needed.
Deck screws come to mind, with a well tapered point. Their coarse thread will give deeper engagement with the plastic and put the plastic adjacent to the hole into tension as the screw enlarges the initially undersized pilot hole as it forms the threat rather than cuts material away.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 29-01-2016, 00:54
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
This really depends on your application. We 3D printed the shooter release mechanism on our 2014 practice robot so we wouldn't have to machine two. We printed 'threads' (they really didn't turn out well) and forced a nylock nut on the back of it and it lasted all season.
However it's important to note the part was being loaded in shear and not in tension. I would not recommend loading a 3D printed / plastic thread in tension for an application that applies a load of more than a few pounds. Conversely, I don't see any problem with using this method to load fasteners in shear. I've done this before for personal 3D printed projects and didn't even bother tapping the hole, I just drilled out the hole with the tap drill and drove the bolt in. YMMV.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 29-01-2016, 02:36
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
In the past I have printed a slightly undersized hole then drilled it to a tight tap diameter, then used machine screws to force threads into it. Alternatively,you can design a part with a hexagonal cavity, pause the print and insert a nut, then allow the printer to seal it inside. Both options have been successful to me when building H class rockets subject to large ejection charges. I print the nosecones and electronics bays and fasten eyebolts to tie the parachute onto these parts. Everything gets blown out of the top of the rocket body and then arrested by a shock cord. Never had an issue with threads pulling loose
Unread 29-01-2016, 02:40
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Someone on my team did that, except he also pointed a heat gun at the 3D printed part before he forced the screw on to soften it around the screw. It worked, but then again he was just making a mount for a computer fan and so didn't need much strength.
Unread 29-01-2016, 03:11
Aaron Ng's Avatar
Aaron Ng Aaron Ng is offline
Team Role: CAD
Aaron Ng is on a distinguished road
bit of a correction: I heated up the bolt only, and with a hot bolt, threaded the plastic. Pointing a heat-gun at the piece would have probably killed it
The threads are clean, and I would think that this is the strongest way to tap a piece of plastic, but that's just my gut feeling.
Of course, it also depends on how deep the threading is, and the bolt size. But like others have recommended, putting a nut on the other end would make a undoubtedly stronger product then my method.
Unread 29-01-2016, 10:40
Justin Ridley Justin Ridley is online now
FRC #0118 (Robonauts)
Justin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond repute
Send a message via AIM to Justin Ridley
It's been mentioned a few times already but I'll reiterate that heat-set inserts are the way to go.
This is what we use:
http://www.mcmaster.com/#heat-inserts/=10w65lb
We've used self tapping inserts for plastic as well, however, a printing lab at JSC recently did a pull out study testing different inserts in different 3D plastics and they found the heat-sets performed best.
They're inexpensive and easy to install with a soldering iron. Just file away any melted plastic that raises above the surface.
-- Justin Ridley --
19 years
27 --> 221 --> 857 --> 118
Unread 29-01-2016, 10:53
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
While there's a lot of fantastic advice on here about how to do this right, in a pinch and when the forces are in the right directions, you can get away with threading directly into a piece of plastic. As an example, we used 100% fill ABS printed pieces as clevises (clevii?) on the 'Snow Problem catapult. Here's an imgur album with pictures of the implementation. Personally, I wouldn't recommend it, and I'm somewhat surprised they've held up for the couple hundred shots we've taken with Perses, but in this particular use case, it worked out to thread directly into the plastic.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 29-01-2016, 11:26
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
jagoldman is an unknown quantity at this point
Last year my team created belt tensioners that were adjusted by turning a bolt that was threaded into the part. We used ¼-20 for this. Our printer is a Stratasys SE Plus. We printed test parts in 3 different settings of sparse, high density sparse and then high density. (Basically increased the infill %, but the software doesn't allow for direct control of that). We found that the latter two, when threaded with ¼-20 and put into a clamp below the threads, were able to lift and hold up one side of a "lab table". By lab table I mean one of those tables with a slate top. it was remarkably strong. These prints are at .13mm layers or less though so be careful when using a non-industrial quality printer. Best of luck!
Unread 29-01-2016, 11:55
Matt_Boehm_329 Matt_Boehm_329 is offline
FRC #0329
Team Role: Tactician
Matt_Boehm_329 has a spectacular aura aboutMatt_Boehm_329 has a spectacular aura about
I actually do this a lot at work for lower load applications. Most bolts can self tap the hole in the plastic if you print the correct size hole and use a higher shell count. (Even the end of a pneumatic) Speaking from experience, if you are going with ABS, PLA, or PET, I would recommend a higher infill than 5% as in one of our experiments it wasn't the hole or threads that failed but the infill. I haven't done extensive testing but using that sort of force you are probably looking at >=25% infill around the threads and a few layers below the bottom of the hole (if the threads don't pass all the way through the part) and the parts would still be considered consumable. (My work printer is .2mm layer height)
Unread 29-01-2016, 12:11
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
What I have always done is print the hole slightly undersized the for the bolt then I force the threads in with the bolt. Works well for non-load bearing part if printed with PTE. Not sure about PLA or ABS.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
