Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
Unread 28-01-2016, 09:56
Malm Malm is offline
FRC #2526 (Crimson Robotics)
Malm is an unknown quantity at this point
Re: Stress testing a Rhino
Originally Posted by sportzkrazzy View Post
Think about it like this. If a robot Can hit both centers of rotation with the span of its front bumpers will you be able to spin off of it? How hard will it be for a defensive driver to line up on you? You can still experience these issues with a drop center wheeled drive as well. Just some food for thought.
That makes sense. In this case, do we expect the tank treads to perform any worse than drop-center wheels with the same spacing?
Edit: Didn't see evanperryg's response, that answers my question
Thank you all!
Unread 28-01-2016, 13:00
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Thank you all!
Maybe slightly but not much worse. Its hard to tell without test how much the extra turning scrub will affect it. Evens solution may give you the best of both worlds though If you have the weight and the space.
