Go to Post A winning robot is the better robot, no matter how it was made or how much it cost. - Chris is me [more]
  #31   Spotlight this post!
Unread 28-01-2016, 11:25
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: Babbitt Bearings in FRC
Originally Posted by RacerX View Post
Volvo?
Sure does look like it.
2017 Season; Game Announcer at
SBPLI Long Island Regional
  #32   Spotlight this post!
Unread 28-01-2016, 11:49
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
I used a babbit bearing recently for professional stuff, part of the reason we didn't use a ball bearing was because of the size of the thing.
http://www.mcmaster.com/#6359k22/=10volie
that's the bearing we used!
On the last FRC bot I worked on, we used bronze sleeve bearings for the wheel shafts, which were running mecanums! Robot still runs perfect nearly 6 years later
Peachtree Regional Volunteer since 2003
  #33   Spotlight this post!
Unread 28-01-2016, 11:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Volvo?
Roger.
http://www.bangshift.com/forum/forum...rescue-mission
  #34   Spotlight this post!
Unread 28-01-2016, 11:54
1966 Corvette, also in the garage. Dad bought it new and it was our Mom's grocery getter when we were kids. It has a 427/425, 4-speed with 4.11's and side pipes. I knew when she was coming to pick me up at school before she was at the school.
Was your mom's first name 'Shirley'? This certainly is not a typical soccer mom vehicle.
  #35   Spotlight this post!
Unread 28-01-2016, 11:55
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Large stationary engines (if you count ships & trains, semi stationary) typically have poured Babbitt bearings. Most car & motorcycle motor have insert Babbitt bearing. As long as you keep the oil flow, the bearing and shafts do not actually touch. Hydrodynamic layer and all that. MEs spend a lot of class time on that. In the end it is really a bunch of Voodoo.
  #36   Spotlight this post!
Unread 28-01-2016, 11:58
MrForbes's Avatar
AKA: Jim
when our kids were real young, I had the blown LS-7 in my 59 pickup. It was fun taking them to day care....
  #37   Spotlight this post!
Unread 28-01-2016, 12:13
RacerX's Avatar
RacerX RacerX is offline
FRC #0948 (NRG948)
RacerX is on a distinguished road
Her name was Sharon, but she had a friend named Shirley...
Just looked over on my desk and see that I have a Babbitt lined bearing in one my paperweights.
Name:	Rod & Piston.jpeg
  #38   Spotlight this post!
Unread 28-01-2016, 12:14
Brian C's Avatar
Doer of Whatever
FRC #1468 (J-Birds)
Unless the soccer field was only a quarter mile away.....
There was a time when poured Babbitt was commonly used throughout the automotive industry. Inserts became a better choice when oiling systems improved.
My guess is that you may have been the envy of some of the other parents
  #39   Spotlight this post!
Unread 28-01-2016, 12:21
MrForbes's Avatar
AKA: Jim
One of the first engines I overhauled was a 1953 Chevy 235, which was the last year they used poured rod bearings. The bearings were still ok, so I just adjusted the clearance using the shims. I was 16 at the time, I think. Those engines used insert main bearings, but they also had shims to adjust the clearance.
  #40   Spotlight this post!
Unread 28-01-2016, 13:24
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
I'm a bit of a muscle guy as well. Helped my grandpa build his drag car (1000hp '69 Vega set up for a 250 shot)
It isn't shiny enough.
  #41   Spotlight this post!
Unread 28-01-2016, 13:26
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Passes everything but a filling station?
  #42   Spotlight this post!
Unread 28-01-2016, 13:37
MrForbes's Avatar
AKA: Jim
Pretty much...and that picture was taken 500 miles from home, I drove it to California.
