Go to Post My strongest FIRST memories, and the teams that leave the biggest impact on me, are teams that seem like they have every reason to give up, but never do. - Chris is me [more]
Unread 27-01-2016, 23:01
jmabartlett jmabartlett is offline
FRC #5499
jmabartlett is an unknown quantity at this point
COTS Worm Gearbox
Does anybody know of any good COTS worm gearboxes that can not be backdriven (or at least VERY hard to backdrive)?
I looked at the WormBox and the RAW box on Andymark but both of them say they can be backdriven. If there is a way to modify one of these so they can not be backdriven that would work too.
Thanks.
Unread 27-01-2016, 23:18
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: COTS Worm Gearbox
Have you looked at the KOP window motors?
They seem to be un-backdrivable, but don't have very powerful motors
Unread 27-01-2016, 23:30
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Here's an option if you have access to a manual mill.
If you don't have access to a mill, but feel like driving across the Bay, PM me and you can come use ours (scheduling tbd).
If that won't work either, these are much more expensive.
Or, depending on the use you could modify something like this.
Lots of options out there depending on your implementation.
Unread 28-01-2016, 02:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
The McMaster worms are more expensive from SDP-SI worms, however the latter will need a stage after it due to the 24 pitch size.
Unread 28-01-2016, 08:46
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
From what Ive been reading about the raw box gearbox is that while it is possible to backdrive people were able to load upwards of 6 totes last year with one gearbox before it ended up backdriving. This year unless you plan on lifting about 100 lbs with the gearbox I would say you should be fine. and if you do find yourself trying to lift that much weight I would consider adding in gas springs to offset the amount of weight on an arm.
If you REALLY need something that doesn't backdrive I would recommend not using snow blower motors, as last year our team found that after a match or two with load on them (weight not electrical) the motors gave out and started to backdrive. they still worked but they didn't stay in place during our matches. you could also design a mechanical mechanism to not backdrive instead of relying on expensive CoTS items.
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
Unread 28-01-2016, 12:26
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
The window motors have a pin that locks the shaft automatically when power is removed - the cars need the windows to stay up even if the car is off. The down side of this is they need to be driven from a "SPIKE" and not a speed controller - which uses PWM to pulse power to the motor. The pulsing does bad things to the pin. Also, as mentioned, they are limited drive power (but great hold power).
Unread 28-01-2016, 12:46
shewejff shewejff is offline
Jeffrey S
AKA: Jeffrey S
FRC #1025 (Impi Robotics)
shewejff is on a distinguished road
I'm guessing that you want this for a winch for climbing. We had a purely climbing robot in 2013. Video here, but skip to the middle of the match to see the actual climbing. We used the WormBox for our first competition. Our robot weighed about 130 lb with bumpers and battery. We had no issues with backdrive at all.
We did have issues with the plastic gears in the WormBox. It doesn't take much at all to break those gears. If we accidentally bottomed out the climbing mechanism, the gears would strip instantly. We went through three sets during our first competition. We switched to metal gears after the first competition, and we had no other issues in the next two competitions.
I would recommend going metal if you want to use a worm gearbox for climbing.
Unread 28-01-2016, 13:14
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
The raw box is pretty hard to back drive if you set it up right. We consistently put 30-50 foot-pounds of torque on it each time we lifted 4 totes last year without backdriving.
We input 2 CIM motors into 10:1 VP's with CIM output shafts, then ran those into the RAW box.
If you keep the lever arm short enough, the raw box is going to have a lot less torque on it than that.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 28-01-2016, 13:15
Best Available Data
FRC #1778 (Chill Out!)
I cannot speak to the quality of this particular item, but Harbor Freight has a winch featuring a worm gear. You would obviously need to come up with your own interface. HF sells several winches, most of which feature a ratchet & pawl to prevent backdriving.
Unread 28-01-2016, 14:18
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Bought one of these to play with. It weighs in at 11lbs! With the frame off and just the gears and drum it's down to 4.5lbs. Some more lightening by replacing the steel drum should make it manageable. A strap to replace the cable and I think it might work. Mathwise, the speed is right and a miniCIM will drive it to climb around 12 inches per second depending on input speed.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
