Go to Post We use the engines of our imagination on the robot all the time. FIRST being an engine of change after all. - Mark McLeod [more]
Unread 23-01-2016, 22:56
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: Andymark rhino drivetrain discussion
R53 Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device shall control one and only one electrical load.
one controller per motor is how i read it
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 24-01-2016, 00:01
REVving up for a new season
FRC #2848 (All-sparks)
Correct. It is 1 motor per motor controller. You can use a PWM Y-Cable (like provided in the KOP) to provide control signal to 2 motor controllers at a time.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 24-01-2016, 00:55
jls667 jls667 is offline
None #2579
jls667 is an unknown quantity at this point
Could I make a PWM Y-cable to control three CIM motors or really three motor controlers for the Rhino drive? Is there a better way to wire and program Rhino drive?
Unread 24-01-2016, 01:16
The simple answer to this is yes (although it is recommended you use the same type motor controller for all 3 motors, 1 motor controller per motor).
Alternatively you could use 3 different PWM ports on your roborio, and make them function the same in code.
Unread 24-01-2016, 01:19
None #2579
I thought using one motor controller for three CIM motors was not allowed.
Unread 24-01-2016, 01:31
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
You are correct. You have to connect each CIM motor to its own (ideally same) motor controller. However the control signal (ie PWM) can be split using a Y-cable to send the same control signal to each of the motor controllers.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
It isn't.
What I believe he's referring to is that you want to have all three motor controllers be the same type. Different types have slightly different responses, and having the motors react differently in the same gearbox can produce "interesting" results.
Unread 24-01-2016, 01:56
None #2579
Thanks for the clarification.
Unread 24-01-2016, 09:43
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Got our Rhino drive train in middle of last week. We have both sides assembled and should be done mounting them on the cross beams today. (We ran out of screws last night and somehow came up 4 short.
To be clear we didn't order the modules from Andy Mark, and instead ordered all of the parts from andy mark with the exception of the metal side plates. We got a local machine shop to cut those out on their waterjet. ( I so want one of those...) :-) We did this hoping to save some time on the order figuring that would be one of the things that would hold up production.
In any case, things actually went together really smoothly.
We are using sheet metal to mount the bumpers. I don't have any pictures, but Team 3238 was kind enough to help us out with the use of their CNC plasma cutter. I'll post pictures of those tomorrow.
Sorry it is so blurry. I was in a hurry when I took the pictures yesterday and seeing that they aren't in focus on my phone is obviously beyond me.
DB
Unread 24-01-2016, 09:56
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by Zebra_Fact_Man View Post
Anyone know how fast these threads are rated for / how fast you've got them to go? Anyone cross 15 ft/s?
I'm sure it's possible... you wouldn't really even need this kind of speed with how tight this field is. We discussed it the sunday immediately after kickoff, and decided that, with the cost of the rhino drive, if we bought it we absolutely had to use it. This wasn't a risk we were willing to take, on a drivetrain we've never tried before, that has yet to see competitive use.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 28-01-2016, 13:04
None #2579
It turns out my team wants to use Talon SRX with CAN signaling. Here is what I think needs to be done to run Rhino Drive:
1. Each Talon SRX would need a different id.
2. Each Talon SRX would need to be daisy chained.
3. Since my team want 3 motors on each side of the Rhino Drive, we will need 6 Talon SRX controllers.
How do I program 3 motors for left and 3 motors for right? Do I setup RobotDrive1, RobotDrive2 and RobotDrive3 each for 2 motors?
Thanks.
Unread 28-01-2016, 14:10
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
If you're using CAN, you can 'slave' two CAN motor controllers to output exactly what a third 'master' controller outputs/is commanded to output.
Unread 28-01-2016, 14:17
AdamHeard's Avatar
Lead Mentor
Anyone willing to post video of a rhino at weight being t-boned by another full weight robot on carpet?
Unread 28-01-2016, 23:48
None #2579
I found some good sample code.
https://github.com/CrossTheRoadElec/...25997ec38d3768
Unread 29-01-2016, 02:07
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A whole lot of teams are going to be a whole lot of disappointed if those treads slide off when pushed sideways.....
