Go to Post Sorry, during my fluid mechanics lectures on drag I must have been designing a gearbox in my mind. FRC season will do that. - sanddrag [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 28-01-2016, 16:20
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: ANNOUNCEMENT: Analog Devices FIRST Sensor Donation
Originally Posted by billbo911 View Post
I have seen the links to Github to acquire examples, but those are mostly geared to LabView. I also see "examples" for Java, but don't I need the libraries to support it?
The required library is on github. It's a single Java file (Java/com/analog/adis16448/frc/ADIS16448_IMU.java). You will need to copy this java file into your robot project (you will have to put it in a subdirectory "com/analog/adis16448/frc" to match the package name).
One caution with this sensor is it is sensitive to magnetic fields and the current Java and C++ code does not do magnetic disturbance rejection... so you may want to consider using the gyro results rather than the fused yaw result.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
