Go to Post Silly FIRST mentor -- actually spending brain power caring about a sporting event occuring during build season! - Aidan F. Browne [more]
Unread 28-01-2016, 02:08
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
ClassNotFound exception
Having to switch between Android Studio for FTC and Eclipse for FRC is hard. I have totally forgotten every little tricks I learned about Eclipse and roboRIO from last year. We copied our RecycleRush code from last season and stripped out the game specific code leaving pretty much a running base to the FirstStronghold code base. It compiled fine but when deploy the code to a simple 4-wheel drive base, it threw a ClassNotFoundException saying it cannot find the Robot class which is the root object of the program. I suspect it has something to do with copying last year's code and missing a rename somewhere in the manifest. The only rename we did was searching for all RecycleRush and replacing with FirstStronghold which are mainly strings for debugging purposes. Does anybody know what we missed?
Unhandled exception instantiating robot org.usfirst.frc.team492.robot.Robot java.lang.ClassNotFoundException
Unread 28-01-2016, 17:07
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: ClassNotFound exception
Can you post code? Either a github repo or your main robot class
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 29-01-2016, 05:02
mikets's Avatar
Software Engineer
You can find our code here:
https://github.com/trc492/Frc2016Fir...old/src/frc492
Unread 30-01-2016, 16:35
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Is your robot class called TrcRobot? It should probably be called Robot, I think.
Programming Captain on team 2399 for the 2016 season.
Programmer on team 2399 The Fighting Unicorns since 2014!
Engineering Inspiration Award GPR 2015
Semi-finalist Buckeye 2015 (thanks 4269 and 1987!)
Unread 31-01-2016, 10:02
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
You just need to edit the package and class name in the build.properties if you don't use the out of the box names from WPILibs wizard. We have a normal class path based on our website and call the main class Team501Robot. Every season I forget to do that the first pull, and have the same problem.
Unread 02-02-2016, 16:36
mikets's Avatar
Software Engineer
Thank you. I think that's what I am looking for. BTW anybody knows where to get the WPILib source code these days? It used to be first forge but I believe that doesn't exist any more. I also vaguely remember if I install the FRC update, the source code is zipped somewhere in some folder. But I searched all over and haven't found it yet.
Unread 02-02-2016, 18:11
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
We distribute the code in ~/wpilib. You can also clone them directly from our repository. The ScreenSteps for that is here: https://wpilib.screenstepslive.com/s...ing-the-source.
