Go to Post Holy 5-year-old-thread-revival Batman!! - Mr. Freeman [more]
Unread 28-01-2016, 17:43
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
Robot Base
What is everyone making their base out of? We are a rookie FRC team and are looking for some ideas.
Unread 28-01-2016, 17:46
Knufire Knufire is offline
Re: Robot Base
If you are a rookie team I'd highly recommend using the Kit Of Parts chassis with some of the upgrades that Andymark sells (specifically the 8" pneumatic wheel upgrade and the wedge upgrade).
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 28-01-2016, 17:51
FRC #5875 (ICE)
Re: Robot Base
We are making one of the basic chassis, but what do we do for where the mechanical stuff actually sits on. Someone else suggested plywood, but someone else said that's not durable enough.
Unread 28-01-2016, 17:55
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
Re: Robot Base
plywood absolutely can be durable enough - but some teams may look past you for alliance partner because they'll think it'll break. If you've got base together, I've frequently used lexan as a bellypan for mounting electronics - but lots of other suggestions here: http://www.chiefdelphi.com/forums/sh...pan+materia l. You could use extruded aluminum or square tubing for connecting your manipulator stuff to your base - along with all sorts of brackets available at andymark and vex.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 28-01-2016, 20:53
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Base
Plywood is fine. Make sure it's an appropriate thickness, though..it comes in lots of varieties!
Also, without knowing what you're trying to attach to it, we can't make really useful suggestions....it might be that something else might work better, depending on your design. I know we are not planning to have a "base" on our robot, because the ball will be traveling through it.
Unread 28-01-2016, 22:15
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: Robot Base
For the past several years we have used donated aluminum road signs. .100 thick works great. Contact local county DOT
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Robot Base
Plywood is great. 1/2" ply is what is suggested for the AM14U3. You do want to use quality plywood, not OSB. Properly attached it greatly strengthens the chassis. You really want to do through bolts with washers on the plywood side at 3 or more places on each side. That triangulates all the sides to keep it square.
Unread 28-01-2016, 17:52
ahartnet's Avatar
Re: Robot Base
If you are a rookie team, I would suggest either assembling the kitbot that y'all got (and adding some sort of wedge like the one on andymark - https://oasis.jsc.nasa.gov/teams/hea.../AllItems.aspx) or making one out of c-channel and corner connects - also available at andymark. You can see what our base last year looked like without wheels: https://www.facebook.com/FRC5414/pho...type=3&theater
